QSC CMX 800Va 2-Ch Low Impedance / 70V Contractor Power Amplifier
Brand:|Model: CMX 800Va|Part # 245-684
QSC's CMX 800Va is an economical and rugged 2-rackspace amplifier that has a power output of 800 watts per channel at 4 ohms.
$870.00
Part # 245-684
  • Flex-Use loading options allow you to drive low-impedance loads down to 2 ohms
  • Flex-Use Input connectivity choices including actively balanced barrier strip, XLR, or 1/4" TRS
  • Flex-Use Output connectivity choices include NL4 Speakon™ and detachable terminal block
  • Rack mountable with chassis less than 16" or 40.6 mm deep
  • 1 dB recessed, detented gain controls for fast, accurate and repeatable settings
  • Recessed rear DIP switches for easy selection of stereo, parallel, or bridged mode operation
  • No changes in performance from the popular CMX series
The CMX 800Va is based upon the proven, rock-solid, reliable performance found in the award winning RMX Series. The CMXa feature sets are designed for wide-ranging application in facilities such as performance halls, houses of worship, sports clubs, gymnasiums, dance venues, pubs, and FGM/BGM systems. The CMXa Series provides unmatched performance, the right power for the job and an affordable price point. CMXa amplifiers incorporate everything QSC has learned in more than forty years of striving to deliver worry-free operations without failures. The design of these amplifiers starts with our world-class power supplies. The CMXa uses a powerful, high-current toroidal transformer and filtering to ensure generous energy reserves. This allows the amplifiers to effortlessly handle high-level transients, even when driving abusive 2 ohm speaker loads. The amplifier output sections feature rugged class AB and class H architecture depending on power level. Efficient class H output sections on the CMX 800Va reduce AC current draw and cut down on waste heat.
All CMXa amplifiers are protected from damage from shorted outputs. Automatic current limiting protects the amplifier from damage until the short is corrected. CMXa amplifiers also feature DC protection systems to prevent loudspeaker damage in the unlikely event of an output transistor failure. DC voltage from the power supply is never passed directly to your speakers, even in the event of an output circuit failure.
The CMXa amplifiers deliver true and accurate studio-quality sound. A full complementary output circuit using high-grade linear output devices generates accurate, flat-frequency response with low distortion. SMT (Surface Mount Technology) triples small-signal component density, enabling high power output in a 2 rack unit chassis. Unlike other designs, CMXa output devices are directly mounted to the heat sink for optimum thermal coupling and cooling.
The V in the model name designates the ability to directly drive 70V and/or 100V distributed loudspeakers. The CMX 800Va must be configured for bridged-mono operation in order to directly drive high-impedance systems.
For installations requiring a transformer isolated output, the CMXa has optional accessories to cover your needs.
Specifications: • Power output, stereo mode (EIA 1 kHz, both channels driven): 500 watts x 2 (8 ohms), 800 watts x 2 (4 ohms), 1,200 watts x 2 (2 ohms) • Power output, bridged mono mode (EIA 1 kHz): 1,500 watts x 1 (8 ohms), 2,400 watts x 1 (4 ohms), 2,000 watts x 1 (70V direct drive) • Distortion (typical): <0.1% 8 ohms, <0.5% 4 ohms, <1% 2 ohms, < 1% 70V direct drive • S/N ratio (20 Hz-20 kHz, 8 ohms): ≥100 dB • Input sensitivity @ 8 ohms: 1.15V • Input impedance: 10k ohms unbalanced, 20k ohms balanced • Voltage gain @ 8 ohms: 46x (33 dB) • Output circuitry: 2-tier Class H • Dimensions: 3.5" (2RU) H x 19" W x 15.9" D • Weight: 44.5 lbs.
Parts Express is authorized to ship QSC products only within the United States, and will only ship QSC products to addresses located within the USA.
  • Power Output (RMS @ 70V)> 400W
  • Weight Range50 to 59 lbs.
  • BrandQSC Audio
  • ModelCMX 800Va
  • Part Number245-684
  • UPC684284058249
  • Product CategoryCommercial Contractor Power Amplifiers
  • Weight50.5 lbs.
View similar products to the QSC CMX 800Va 2-Ch Low Impedance / 70V Contractor Power Amplifier
in the Commercial Contractor Power Amplifiers product category.
