Pyramid PS26KX Power Supply 6-15 VDC 22A
Brand:|Model: PS26KX|Part # 120-548
This heavy duty power supply offers features and performance not normally found in this price range. Variable output voltage, dual current/voltage meters, and short circuit/overload protection make this supply an outstanding value.
List Price$368.99
You Save58%
$154.88
Buy 4+$151.50
Part # 120-548
  • Variable voltage adjustment
  • Great test station power supply
This heavy duty power supply offers features and performance not normally found in this price range. Variable output voltage, dual current/voltage meters, and short circuit/overload protection make this supply an outstanding value. The built-in fan keeps the unit cool, even when operating at the full rated output for extended periods of time. Features front mounted binding posts for easy hook-up. Heavy duty steel housing with short circuit and overload protection.
Specifications: • Output voltage: 6-15 VDC (variable) • Output current: 22 amps • Ripple voltage: Less than 1mV at rated output • Input voltage: 120 VAC, 60Hz • Weight: 20 lbs.
  • BrandPyramid
  • ModelPS26KX
  • Part Number120-548
  • UPC068888701693
  • Product CategoryPower Supplies
    (5 Reviews)
  • Weight18.9 lbs.
View similar products to the Pyramid PS26KX Power Supply 6-15 VDC 22A
in the Power Supplies product category.
Pyramid PS26KX Power Supply 6-15 VDC 22A is rated 3.6 out of 5 by 5.
Rated 3 out of 5 by from Very short lifespanI have been using this power supply for several years now to power some 12v boat depthfinders on a counter display in a retail store. I ran two to power the counter, with no more than 5or 6 units on each power supply, which was less than a 10 amp draw. While they worked, the poser supplies did great. The built in cooling fans were a nice feature as well. But my biggest problem is the short lifespan. The longest I have had one of these work is about a year and a half. I have even had two units die is less than 3 months. Granted, the units were being used 16 hours a day, 7 days a week, but that's what they are "supposed to" be able to do. I have since replaced one with a unit from Radio Shack rated for 15 amps, and it has worked flawlessly for over two years. So when my last Pyramid died 3 months ago, I replaced that one with a Radio Shack unit as well. For the price, these units should last AT LEAST 5 years. I was very disappointed.
Date published: 2014-11-11
Rated 5 out of 5 by from nice power supplyusing it as a power supply for a heated build platform for a 3d printer. allows variable temperature and typical operation is right at 13.8v at 9.5 amps. handles it just fine
Date published: 2014-03-28
Rated 3 out of 5 by from Decent Basic Power SupplyI bought this as a benchtop supply for 12v automotive component testing. The voltage needle display is only a reference, make sure you check it with a good DVOM if you're trying to be precise. I also had it fail after a year or so of driving a fuel injector test bench. Perhaps a good diode on the output side or better input line conditioning may have helped prevent the failure. I honestly don't expect much out of this brand, so chalk it up to being a consumable test item.For the casual user, it's a decent unit. Adjustable supply voltage is a nice feature even if you need to constantly verify the setpoint.
Date published: 2013-01-22
Rated 4 out of 5 by from meets requirementsLighted meters would be great..Over all good power supply..We are using it for testing of Mobile Video Recorders.
Date published: 2012-05-07
Rated 3 out of 5 by from Pyramid PS26kxWere is the lighte on the meders
Date published: 2008-08-06
  • 2016-02-06T07:24CST
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_120-548, PRD, sort_mostRecent
Where can I send my Power supply PS-26kx to get it repaired???
Asked by: rjzip
You will need to check with the manufacture for a list of their repair shops.
Answered by: MattW
Date published: 2015-04-01
Looking for power supply to run car amplifiers,  best solutions? Help!
Asked by: bigk71
Any of our bench top power supplies (like this one) will work for this application as long as you use one with enough current draw to handle the amp load. You do not want the amperage on the fuses of the amp to exceed the about of amperage the power supply can produce.
Date published: 2014-02-10
can it supply 22 amps at all the voltages from 6 up or is 22 amps only available at 13,8 volts?
Asked by: raybee
According to the manufacturer's specifications (see the manual to the right, under "Manuals/Resources"), the 22A output is at 13.8VDC.
Answered by: RussR
Date published: 2012-04-27
  • 2016-02-06T08:47CST
  • loc_en_US, sid_120-548, PRD, sort_recentQuestionsFirst
