Pyramid PS15K 10 Amp Power Supply 13.8 VDC 10A
Brand:|Model: PS15K|Part # 120-538
This is a perfect power supply to test most high power car stereos, cellular phones, and other 12V devices that draw up to 10 amps. Features front mounted binding posts and a cigarette lighter jack for increased versatility. Heavy duty steel housing with short circuit and overload protection.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$168.99
You Save59%
$69.50
Buy 4+$68.77
Part # 120-538
Specifications: • Output voltage: 13.8 VDC (fixed) • Output current: 10 amps (cont), 12 amps (surge) • Ripple voltage: Less than 1mV at rated output • Input voltage: 120 VAC, 60Hz • Weight: 11 lbs.
  • BrandPyramid
  • ModelPS15K
  • Part Number120-538
  • UPC068888701679
  • Product CategoryPower Supplies
    (8 Reviews)
  • Weight10.3 lbs.
Pyramid PS15K 10 Amp Power Supply 13.8 VDC 10A is rated 4.75 out of 5 by 8.
Rated 5 out of 5 by from ReliableI've had this power supply for many years, and it's never skipped a beat. I mainly use it in my shop now, to power an old Blaupunkt car head unit and amplifier that I had laying around. Before that, it powered a 125 watt amp in my house for a sub. It does get warm, in fact the small heat sink on the back get's hot. But a small fan takes care of that easily. I've never had it shut off due to heat, but I have had it go into protection mode when I shorted wires or put a large load on it suddenly. Turn it off, then back on and you're good. Highly recommend.
Date published: 2015-02-08
Rated 5 out of 5 by from CLEAN 13.8 VOLTAGEPERFECT POWER SUPPLY FOR MY TWO WAY RADIO REPEATER. CLEAN NOISE FREE POWER WITH PERFECT AMPERAGE FOR RUNNING A 7 WATT TRANSMITTER AND RECEIVER. I WOULD TELL ANYONE TO PURCHASE THIS POWER SUPPLY WITH THE SAME SITUATION THAT I HAVE FINDING CLEAN 13.8 VOLTAGE. VERY PLEASED !!!
Date published: 2014-09-20
Rated 5 out of 5 by from Great little supply!This is a very good supply for any project that requires a 12V nominal DC supply. Just keep in mind that the supply is only rated for 70% continuous load.. You can only draw 100% continuously for about 15 minutes or 80% for 25 minutes and then it will kick out on safety overload. If you keep that in mind it makes an excellent well engineered supply.
Date published: 2014-05-31
Rated 5 out of 5 by from Grate Compact Power SupplyIt is hard to find a linear power supply these days. The PS15KX is well built, no noisy fans, very low ripple and noise. I ran a 6A load on it overnight. It got quite hot, but survived without any damage. The cigarette lighter socket is an asset too.
Date published: 2009-02-07
Rated 5 out of 5 by from Great product for cost.Using as a power source for the electro magnet's in a early 40's cinema speaker. Does a great job.
Date published: 2008-02-09
Rated 4 out of 5 by from Good all around supplyThis is my second pyramid. First was for amateur radio. This is for my wife's telescope. Solid product
Date published: 2008-01-02
  • 2016-02-08T06:50CST
  • co_hasreviews, tv_0, tr_8
  • loc_en_US, sid_120-538, PRD, sort_mostRecent
What are the demension of PS15K
Asked by: gefell19
This power supply measures 8"L x 7.16"W x 4.72"H.
Date published: 2015-11-24
  • 2016-02-08T07:23CST
  • loc_en_US, sid_120-538, PRD, sort_recentQuestionsFirst
