Pyle PYD1919 4-Channel 19" Rackmount Mixer
Brand:|Model: PYD1919|Part # 248-4090
Your Pyle Pro PYD Series mixer is a sophisticated control center, perfect for mixing sound from multiple signal sources such as microphones, tuners, turntables, and more. The PYD1919 features 2 turntable, 8 line level, and 2 mic inputs.
Part # 248-4090
  • Effects send and receive
  • Effect and EQ on/off switches
  • Blue LED level display Meters
  • Red light illuminated power on/off switch
  • Blue light illuminated channel volume control
  • Top mounted 12V BNC connector for gooseneck lamp (not included)
  • Dual mic inputs with talkover
Your Pyle Pro PYD Series mixer is a sophisticated control center, perfect for mixing sound from multiple signal sources such as microphones, tuners, turntables, and more. This mixer is ruggedly constructed for home or professional use. Wide range of volume controls permit you to adjust sound levels accurately to achieve just the right mix for playing through your speaker system or for recording. The PYD1919 features 2 turntables, 8 line level, and 2 mic inputs as well as a 10-band graphic equalizer for the right and left channels. Measures 19" W x 9-7/16" D x 4-1/4" H.
Specifications: • Impedance: (Mic 1-2) 1.5 mV bal/600 ohms unbal, (Phono 1-2) 3.0 mV/50K ohms, (Line 1-8) 150.0 mV/27K ohms • Output level: (Amp) 2.0 V/10k ohms, (Zone) 2.0 V/10k ohms, (Record) 150 mV/10k ohms • Frequency response: 20 Hz – 20 kHz ±3 dB • S/N ratio (at 1 kHz): (Mic) >60 dB/1.5 mV input, (Phono) >70 dB/3.0 mV input, (Line) >80 dB/150.0 mV input • Distortion: (Mic) 0.20%, (Phono) 0.05%, (Line) 0.03% • MIC tone control: (Treble) 10 kHz; +10/-30 dB, (Mid) 1 kHz; +10/-30 dB, (Bass) 100 Hz; +10/-30 dB • Power source: 120/230 VAC, 60/50 Hz.
  • Special FeaturesRack Mountable
  • Stereo Line Input Channels4
  • Mic Inputs2
  • BrandPyle Audio
  • ModelPYD1919
  • Part Number248-4090
  • UPC068888892315
  • Product CategoryDJ / Club Mixers
  • Weight12 lbs.
View similar products to the Pyle PYD1919 4-Channel 19" Rackmount Mixer
in the DJ / Club Mixers product category.
