Pyle PT6800 3000W Power Amplifier
Brand:|Model: PT6800|Part # 248-4064
Pyle Pro's new PT series PA amplifier gives you the power and versatility you need in a professional sound system. With up to 3,000 watts of power the PT6800 is well suited for amplifying music or vocal program material.
  • 4 banana plugs speaker connection
  • 2 combo plugs speaker connection
  • Bridgeable into single speaker mono output
  • Dual RCA and dual combo inputs
  • Off/30 Hz/50 Hz low cut filter
  • Dual heavy duty fan cooled aluminum heatsinks
  • Mono and bridged LED indicators
Pyle Pro's new PT series PA amplifier gives you the power and versatility you need in a professional sound system. With up to 3,000 watts of power the PT6800 is well suited for amplifying music or vocal program material. It can be used for live bands, office paging systems, public announcements, or a variety of other installations. Features a stereo/mono/bridge input selector, channel A & B separate volume control, and a detachable AC cord.
Specifications: • Input impedance: 20k ohms • Continuous output power (Stereo mode): 400 watts x 2 (20 Hz - 20 kHz, 8 ohms), 600 watts x 2 (1 kHz, 4 ohms), 450 watts x 2 (Max. power, 8 ohms), 650 watts x 2 (Max. power, 4 ohms), 3,000 watts x 2 (Peak power, 8 ohms) • Continuous output power (Bridged mode): 1,000 watts x 1 (20 Hz - 20 kHz, 8 ohms), 1,200 watts x 1 (1 kHz, 8 ohms), 6,000 watts x 1 (Peak power) • THD: 0.1% • Frequency response +/- 3 dB: 10 Hz - 50 kHz • Input sensitivity (for rated output power): 1.0V • Signal-to-noise ratio (A-weighted): 100 dB • Impedance: Stereo 4-16 ohms, Bridged 8-16 ohms • Power requirement: 120 VAC,60 Hz • Dimensions: 3.46" H x 18.98" W x 14.65" D (88 x 482 x 372 mm).
  • Power Output (RMS Per Channel @ 8 ohms)400 Watts
  • Output Channels2
  • Weight Range30 to 39 lbs.
  • BrandPyle Audio
  • ModelPT6800
  • Part Number248-4064
  • UPC068888893473
  • Weight35.2 lbs.
View similar products to the Pyle PT6800 3000W Power Amplifier
Part # 248-4064
