Pyle PPEQ150 Dual 10 Band Stereo Graphic Equalizer
Brand:|Model: PPEQ150|Part # 248-4558
The PPEQ150 graphic equalizer by Pyle Pro has dual 10 bands EQ with blue LEDs.
List Price$157.99
You Save56%
$69.89
Part # 248-4558
The PPEQ150 graphic equalizer by Pyle Pro has dual 10 bands EQ with blue LEDs. VFD display screen.
Features: • 2 RCA line inputs • 2 RCA line outputs • 2 RCA line outputs for REC • bass, midrange, high gain control • left and right channel volume gain control • 110/220V power switch. Includes removable rack mount brackets.
Specifications: • Dimensions: 17" W x 9" H x 2.2" D • Weight: 5 lbs.
  • BrandPyle Audio
  • ModelPPEQ150
  • Part Number248-4558
  • UPC068888899086
  • Product CategoryEqualizers
    (3 Reviews)
  • Weight5.2 lbs.
View similar products to the Pyle PPEQ150 Dual 10 Band Stereo Graphic Equalizer
in the Equalizers product category.
Pyle PPEQ150 Dual 10 Band Stereo Graphic Equalizer is rated 4.3333 out of 5 by 3.
Rated 4 out of 5 by from Great internal components...I have had this unit for a couple months now with no issues at all... Internally... The slider LEDs are a hit and miss and noticeable changes in each frequency band doesn't hit until close to the top and its sensitive, plus the LEDs tend to flicker sometimes but all in all, this is the budget EQ, it's absolutely wicked on my ALESIS power amplifier and Yamaha NS-500M tower speakers.
Date published: 2015-12-23
Rated 5 out of 5 by from so greateI bought this 2 weeks ago and i realy like it thank for the best experince
Date published: 2014-08-15
Rated 4 out of 5 by from Pyle 10 band EQAfter purching a very confusing (and much more expensive) ART EQ I sent it back and purchased a Pyle 10 band EQ.The Pyle EQ is easy to intall on a typical home theater system and works very well.
Date published: 2013-08-08
  • 2016-02-10T06:56CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_248-4558, PRD, sort_mostRecent
can the record out rca's be used for another amp ? what I mean is I have an amp for my mains and an amp for the lows, I need to cover the lows as well.
Asked by: spunk
To answer my own question I now see that it has 2 RCA outputs , I would withdraw this questionif I could.
Answered by: spunk
Date published: 2014-11-03
Does this equalizer give off a audible hum?
I ask this because my system is less than 8 feet from where I sit and view/listen. I was considering the AudioSource model you sell but, read a review that stated that if you are playing score or classical music, you will hear a hum. My system is not in a cabinet and unable to do so unless a major investment is made.
Asked by: bradje
This unit should not have any noise in it or produce any noise. Inter-connection patch cords (if faulty) could cause this. You can purchase with the confidence that PE is the best at customer support. If you buy and have a problem, call them. Lots of things can cause low 60hz. hum and someone may have a problem elsewhere.
Answered by: Nitnub
Date published: 2012-12-12
does the equalizer give the stereo more bass
pyleppeq150 dual 10 band
Asked by: blarneystone
Think of an equalizer as a glorified detailed set of tone controls. Perhaps your stereo has bass, midrange and treble or high controls. This would be a three band equalizer. Each control can influence about 1/3 of your audio sound spectrum.Now break this same range into 10 sections. In a 10 band equilizer you can increas or decrease each section to shape your sound to your desired sound.Understand that any system has limitations based on the various parts of your system. An equilizer will not provide more than a system is physically capable of. It Will get the most out of your system.Yes this Pyle Pro EQ will allow you to increas lower bass frequencies or decreas mid and high frequencies to obtain a stronger bass sound.The more bands an equilizer has the more control over your sound you will have.Because your sound is adjusted at a line level, you must have a method of placing this between your preamplifier section and your power amp and speakers. Some stereos have a jumper between the pre amp and power amp, others do not. You can use record output to go to the EQ line in and route the EQ output to a tape Mon or monitor input on your receiver ( if you have one). If you have neither then you will require some technical modifications to be made.If you don't have these and wish to not make a technical modification, then consider a powered sub-woofer with outputs for your existing speakers.
Answered by: Nitnub
Date published: 2012-10-15
Is there s way that i can get a back view of this EQ?
Asked by: ericmclogan
go to the pyle webpage
Answered by: digitalhaven 53
Date published: 2015-12-06
  • 2016-02-10T07:44CST
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_248-4558, PRD, sort_recentQuestionsFirst
