Pyle PMX402M 4-Ch 400W Powered Mixer with MP3 & USB Input
Brand:|Model: PMX402M|Part # 248-4182
The PMX402M by Pyle is the all in one mixer with 4 channels and a 5 band graphic equalizer. Has balanced microphone inputs, high impedance microphone/line inputs, and CD inputs. Operate a MP3 player through the four key touch LCD display.
List Price$317.99
You Save51%
$155.67
Part # 248-4182
  • USB 2.0 terminal and LCD
  • Each channel has tone control
  • Effect control
  • TAPE input, REC output
  • Channel tone adjust (high/low, ±15 dB)
  • AUX/TAPE/effect feedback input
  • Effect send
The PMX402M by Pyle is an all in one mixer with 4 channels and a 5 band graphic equalizer. Has balanced microphone inputs, high impedance microphone/line inputs and CD inputs. Operate a MP3 player through the four key touch LCD display.
Specifications: • Master output: 400 watts 4 ohms • Input impedance: Lo-Z Mic 1K ohms, Hi-Z Mic/Line 33K ohms • Tape playback: 10K ohms • Input level: Lo-Z Mic -50 dB, Hi-Z Mic/Line -20 dB • Tape playback: -10 dB • Rec output level: +22 dB (max) • Dimension: 15.75" x 12.01" x 7.87". Specifications provided by manufacturer.
PRODUCT SPECIFICATIONS
  • Mixer TypeAnalog
  • Special FeaturesDigital Effects
  • XLR Mic Inputs< 6
  • BrandPyle Audio
  • ModelPMX402M
  • Part Number248-4182
  • UPC068888894807
  • Product CategoryPowered Mixers
    (2 Reviews)
  • Weight22.3 lbs.
View similar products to the Pyle PMX402M 4-Ch 400W Powered Mixer with MP3 & USB Input
in the Powered Mixers product category.
Pyle PMX402M 4-Ch 400W Powered Mixer with MP3 & USB Input is rated 2.5 out of 5 by 2.
Rated 1 out of 5 by from don't wast your timefirst one out of the box popped when ever you touched the master volume. returned it. Second one would not even power up.
Date published: 2013-08-30
Rated 4 out of 5 by from Mini PA Package PlusFor a small inexpensive amp/mixer this has it all and then some. I'll be using it for a practice bass amp at times, a PA at times, A powered playback for MP3's & CD's, for my son to practice drum with. It has it all. And best of all it didn't cost that much! Parts Express service is the BEST...
Date published: 2009-10-08
  • 2016-02-05T06:36CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_248-4182, PRD, sort_mostRecent
What speakers for Pyle Pro402M?
My wife bought this for the kids' band. I dont know anything about this stuff. What speakers should we buy? What are the most powerful speakers we can get away with and not fry the mixer?thanks
Asked by: azosteve
Your concern for damaging the mixer with improper speakers is well-placed, however, the impedance (rather than the "power") of the speakers is critical to safe and proper operation. The speakers I've linked below are a popular and affordable choice for this sort of thing, if you decide to look for something else, just make sure you get 8 ohm speaker cabinets, and nothing lower than that.
Answered by: RussR
Date published: 2011-06-15
What are the specifications on power and this product's adaptability to 8-ohm speakers?
First: is "400 watts" in terms of RMS or peak?Second: the manual for this product states that "each [speaker output] is rated at 8 ohm minimum impedance. Total minimum load for the amplifier is 4 ohms. You may connect either 1-4 ohm,1-8 ohm or 2-8 ohm speaker cabinets. Do not below rated minimum impedance."I just built two speaker cabinets of 8 ohms each and am looking to get at least 150W out of each. If this product would indeed handle both of these at once, that would mean that the effective power would be halved, right (i.e. 400W at 4 ohms = 200W at 8 ohms)?
Asked by: Coxy1214
You are correct. If an amplifier will deliver 400w at 4 ohms, it should deliver approximately 200w at 8 ohms. This powered mixer will handle both your 8 ohm speakers, and should provide plenty of power for your needs.
Answered by: RussR
Date published: 2011-06-03
  • 2016-02-05T07:11CST
  • loc_en_US, sid_248-4182, PRD, sort_recentQuestionsFirst
