Pyle PLMR18 Marine Stereo USB Inputs
Brand:|Model: PLMR18|Part # 267-7250
The PLMR18 marine stereo by Pyle is an AM/FM tuning radio with USB inputs. Features a 30 station memory with a dot matrix LCD display.
- Order Soon - Only 3 Left In Stock
List Price$111.99
You Save59%
$46.00
Part # 267-7250
  • Encoder volume, bass, treble, balance, and fader control
  • 2 Channel RCA line out
  • USB interface (Decode MP3 WMA)
  • SD/MMC slot
  • Aux input
  • Remote control
  • Marine coating
Specifications: • Power output: 4 x 50 watts • Dimensions: 7.0" W x 6.29" D x 1.9" H.
  • Receiver TypeDigital Media Receiver
  • USB InputFront
  • Aux InputFront Panel
  • Remote ControlIncluded
  • Head Unit SizeSingle DIN (2" high)
  • Preamp Outputs2-Channel
  • BrandPyle Audio
  • ModelPLMR18
  • Part Number267-7250
  • UPC068888889186
  • Product CategoryCar Stereos
    (2 Reviews)
  • Weight2 lbs.
View similar products to the Pyle PLMR18 Marine Stereo USB Inputs
in the Car Stereos product category.
Pyle PLMR18 Marine Stereo USB Inputs is rated 4.0 out of 5 by 2.
Rated 3 out of 5 by from pretty darn good butwell purchased two in april of 2012 for 2 motorcycles; one hasn't been installed yet bike is under restoration i did have a chance too use the other in my 2003 Honda VTX 1800c full dresser... the fidelity is excellent up to around 80 mph i have 4 speaker fairing with the unit and one speaker is a sub woofer it really sounds awesome but the SD card reader stopped functioning right after the 1 year warranty ran out the USB port works well except if you hit a bump you are liable to lose it; i used some Velcro to resolve the issue works like a charm... the aux in works flawlessly... but lately after approximately 18 months the unit at times cuts off then comes back on in the radio mode the mode switch works sometimes but it switches from USB too radio and at times it wont recognize the USB media in the radio ..but aux in works fine (its like a short in the radio lately from the road bumps) hardly since it says marine and the water pounds a boat worst than a smooth road on a big cruiser but i jus ordered 2 more for 50 buck what do you want. very good deal! also very loud =0)
Date published: 2013-10-06
Rated 5 out of 5 by from best $49 I ever spentNo more hassles with CD's, works and sounds great, and for $49 you won't mind taking it outdoors in your ATV or boat and exposing it to the elements....
Date published: 2012-05-18
  • 2016-02-09T06:32CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_267-7250, PRD, sort_mostRecent
Does this unit have a weather band ?
Asked by: Sisko
This unit does not have a weather band.
Date published: 2015-02-18
Does the unit come with a generic wiring harness ? I want to use it as an audio system in my garage. So, I need a way to hook it up outside of a car or boat.
Asked by: GH330
Yes this comes with a wire harness that has bare ends for any type of connection.
Date published: 2014-04-01
Is the remote UV, line of sight or RF not line of sight.
Asked by: rotaryred01
not sure set it and forget ... trick too uses while driving a motorcycle lol.. but works fine when i point at it, just don't use it much honestly use either the sd or usb media or aux in
Answered by: MRBIGDADDY911
Can the 4 channel output be bridged into two for stereo only use?
Asked by: nicholsjh
No. Amplifier circuits are designed specifically to be able to do that. In a device such as this - you will most likely have catastrophic failure and the warranty will be voided.
Answered by: markajh
Date published: 2013-01-16
what is "marine coating"?
Asked by: aluminaughty87
Equipment used in marine application are protected by special coating like marine paint for boats and ships and related equipment. The electronics on the other hand are similarly protected by coating the circuit board with corrosion resistant spray or similar coating like having them dipped on protective solution. The same applies to other electronic parts as well as other components. Mechanical parts can be treated number of ways and visible parts as faceplate treated to prevent discoloring and smudging due humidity. This type of protection is particularly important on sea going vessels due the corrosive nature of saltwater. The air at sea is saturated by humidity that contains salt and is thus more destructive that sweet water lakes and rivers. The quality or type of coating, of cause depends of the manufacturer.I have used products that generally protects the circuit board and there is major difference in longevity between the protected equipment and unprotected.
Answered by: PasiPT
Date published: 2015-03-17
So can I load a USB thumb drive up with MP3 files and stick it in this unit's USB port, will this unit see the files and play them?
Asked by: Steve1
Yes, this unit will decode standard MP3 and WMA files from your thumb drive.
Answered by: RussR
Date published: 2012-05-03
  • 2016-02-09T07:00CST
  • co_hasquestionsanswers, tq_7
  • loc_en_US, sid_267-7250, PRD, sort_recentQuestionsFirst
