Pyle PLHR76 7" TFT-LCD 16:9 Monitor with Headrest Shroud
Brand:|Model: PLHR76|Part # 205-508
High resolution 7" TFT-LCD monitor from Pyle features a 16:9 wide-angle display, two audio/video inputs including one front-mounted jack, front headphone output, and front panel controls.
List Price$126.99
You Save56%
$55.98
Buy 3+$51.49
Part # 205-508
  • 16:9 widescreen, 7" TFT-LCD active matrix high-resolution display monitor
  • Slim-size wireless remote control
  • Two audio/video inputs, front panel controls, and wide, off-axis visibility
  • On-Screen Display
  • Includes headrest shroud and universal stand-style bracket
High resolution 7" TFT-LCD monitor from Pyle features a 16:9 wide-angle display, two audio/video inputs including one front-mounted jack, front headphone output, and front panel controls. Includes a headrest shroud and universal stand-style bracket.
Specifications: • Aspect ratio: 16:9 • Video format: NTSC/PAL • Back light: High brightness CCFT • Power requirements: 12~14.4 VDC, < 9W • Mfg. #PLHR76.
  • BrandPyle Audio
  • ModelPLHR76
  • Part Number205-508
  • UPC068888875974
  • Product CategoryMobile LCD Monitors
    (9 Reviews)
  • Weight1.65 lbs.
View similar products to the Pyle PLHR76 7" TFT-LCD 16:9 Monitor with Headrest Shroud
in the Mobile LCD Monitors product category.
Pyle PLHR76 7" TFT-LCD 16:9 Monitor with Headrest Shroud is rated 3.7778 out of 5 by 9.
Rated 5 out of 5 by from good productibought for my headrests in my suburban good picture for the price
Date published: 2010-04-08
Rated 4 out of 5 by from Follow-up ReviewBought the monitor in June. The monitor is still working fine. I probably have several hundred hours on the backlight by now. I did notice that the unit does not like to turn on when using the front panel control. The secret is to push and release the power button quickly! If you do a slow push of the button, the monitor will not turn on. Stab the button and it turns on every time. No buyer's remorse here.
Date published: 2009-11-14
Rated 2 out of 5 by from Poor assembly qualityOf the 3 I purchased, the first one had the screen mounted upside down, the second had the lense missing over the infrared port and the sensor pushed in. I haven't tried the third yet. As I use these as surveillance camera monitors in vending machines, I set them up once and am I done. I just rotated the camera upside down to make the first one work, and used the hard keys to set the second one up, instead of the remote. I would have been bummed if I had used these in the back of headrests for video monitors. Be careful, these are inexpensive monitors and you get what you pay for.
Date published: 2009-08-10
Rated 4 out of 5 by from Works fine!Much brighter that other monitors I've seen. Off-axis viewing is good in color, but poor with a B&W picture. I'm using the monitor to view an infrared surveillance camera that switches to B&W at night. This isn't the application the monitor was designed for, but it does an adequate job. Not sure how long the backlight will last under these conditions. Remote is very easy to use and after you loose the remote, the front panel buttons will get the job done. Yeah, the stand is cheesy. I saw this Pyle monitor on the PE website initially. Decided to do a web search to see if there was a lower price somewhere else. BINGO! Found the EXACT same monitor (new not - a referb) for $68.99 at another site. I'd feel like chump paying 99 bucks, so I put one of those $68.99 monitors in my cart and clicked "Checkout". Ha! NOW the $111.00 shipping and handling charge got tacked on! Not such a good deal after all. Went back to PE and ordered. Never any games at PE..
Date published: 2009-06-21
Rated 1 out of 5 by from UnreliableWill not turn on every time, neither with the remote nor with the "ON" button on the set.A definite piece of junk.
Date published: 2009-04-02
Rated 4 out of 5 by from Great ValueThis monitor is truly a great value. A wide range of menu options and crisp picture make this unit hard to pass up.
Date published: 2009-04-01
  • 2016-02-10T06:59CST
  • co_hasreviews, tv_0, tr_9
  • loc_en_US, sid_205-508, PRD, sort_mostRecent
i just bought a used Pyle PLHR76 montior. The power cord only has a small end with 7 holes going arond in a circle and one small hole in the middle. Where can I find an adapter to plug it into a normal outlet?
Asked by: jkcor
This connector and pigtail is proprietary to Pyle, you will have to contact them for a possible replacement.
Date published: 2014-09-15
My main DVD head unit in my car has an RCA jack for video output for external/ additional video displays. What input connections does this unit have?
Asked by: Tuanapplied
This monitor has two yellow composite video inputs. If your DVD head unit has composite video outputs, they will work together.
Date published: 2011-03-25
  • 2016-02-10T07:50CST
  • loc_en_US, sid_205-508, PRD, sort_recentQuestionsFirst
