267-7008_ALT_0
267-7008_ALT_1
267-7008_ALT_2
267-7008_ALT_3
267-7008_ALT_4
267-7008_ALT_5
Pyle PLCM10 License Plate Mount Rear View Camera
Brand:|Model: PLCM10|Part # 267-7008
Eliminate the worry of an unexpected blind spot when having your car in reverse. Now you can see all angles when backing up with Pyle's PLCM10 rear view camera. Mounts directly to the license plate.
List Price$59.99
You Save55%
$26.97
Part # 267-7008
  • Mounts directly to the license plate
  • Standard composite video output
  • High resolution: 380 TV lines
  • Low light illumination: 1.5 lux/f1.2
Eliminate the worry of an unexpected blind spot when having your car in reverse. Now you can see all angles when backing up with Pyle's PLCM10 rear mount camera. Mounts directly to the license plate. Your view is still visible in the dark with a night vision sensor. One-year manufacturer's warranty.
Specifications: • Resolution: 380 TV lines • Image sensor: Ov 7910 Color CMOS • Lens: 6 mm, 92° • Low light illumination: 1.5 lux/f1.2 • Video output: RCA 1.0Vp-p composite video @ 75 ohms • Output standard: PAL/NTSC • Power requirements: DC 12V • Operating temperature: 14°F ~ 122°F (-10°C ~ 50°C) • Dimensions: 8" L x 1.3" H x 1.26" D.
  • BrandPyle Audio
  • ModelPLCM10
  • Part Number267-7008
  • UPC068888885324
  • Product CategoryRear View Cameras
    (3 Reviews)
  • Weight0.45 lbs.
Pyle PLCM24IR Rear View Camera
Part #  267-7368
Pyle PLCM22IR Night Vision Camera
Part #  267-7366
View similar products to the Pyle PLCM10 License Plate Mount Rear View Camera
in the Rear View Cameras product category.
Pyle PLCM10 License Plate Mount Rear View Camera is rated 4.0 out of 5 by 3.
Rated 4 out of 5 by from Follow-up reviewI Purchased this Camera back in 2009, and It still works as good as the day I purchased it (knock on wood) . The only problem I've seen with the camera is the screws corroded badly on the back side of the unit (which does show up in the clear front section as the screws do thread into that part). You may want to silicone over the screws or put some paint on them before they start to rust, other than that works as designed !
Date published: 2012-05-24
Rated 4 out of 5 by from Perfect for what you pay for!This purchase was well worth it for the money. I purchased it and received it in the mail with more than appropriate packaging (godsend) a few days later. After taking about an hour to install I got it all set up and was worried about a white glare, but realized it has almost like night vision. It works very well. I'd recommend it to anyone if they aren't looking for a very high-end camera.
Date published: 2011-12-20
Rated 4 out of 5 by from Gets the job doneNot a bad rear view camera for the money.Works great in low light unlike other cameras I've used. The motion is not smooth with this camera, but it's not meant to be a high end unit. There are no installation instruction, but it is a straight forward install (fused wire goes to reverse lamp positive lead and other black wire to ground. RCA wire is your video signal). The camera comes with about 15 feet of extension RCA cable (perfect for most installs) The power leads are about 2 feet long . Camera doesn't state which side is up, Install the camera with the wires coming out the bottom. The camera is a true reverse image, so left and right are proper when hooked up to any monitor / display.
Date published: 2009-12-07
  • 2016-02-08T06:28CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_267-7008, PRD, sort_mostRecent
Hello, I bought a Stereo PylePDLNB78i and Camara rear PLCM10. The radio works just fine. I'm having trouble installing this camara to my Ford Explorer 2004, I can't figure out on what is the cable that I need to attach to the radio to male the camara work
Asked by: ceci0226
Date published: 2015-05-27
Need help.  No directions with camera and wiring diagram doesn't show the orange wire leads on the video cable.  What are they for? And exactly how are the power leads supposed to be hooked up?
Asked by: jeffro34
Date published: 2015-04-14
where does the power and ground wire connect toon a pyle view 10 back up camera
Asked by: finney
You need a 12vdc source and it connects to the red wire. The yellow is for the video.
Answered by: TomI
Date published: 2015-03-24
Asked by: finney
The power and ground wires will be connected to the reverse light in the vehicle, so the camera is only on when the car is in reverse.
Hello, what is the length of the video wire with Pyle PLCM10 ? Thank you Best regards
Asked by: fredlab
The length of the video cable in this kit is 16.5 feet.
Date published: 2015-02-05
  • 2016-02-08T07:10CST
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_267-7008, PRD, sort_recentQuestionsFirst
