Pyle PLAD3300D 1x3600W (1.3 ohm) Digital Monoblock Amplifier
Brand:|Model: PLAD3300D|Part # 267-764
Specifications: *Power output: 600 watts RMS x 1 (4 ohm load), 3,600 watts max x 1 (1.3 ohm load) *Variable low pass crossover *Variable subsonic filter *Total Harmonic Distortion: < 0.1% *Signal to noise ratio: > 90 dB *Phase control: 0~180°*One-year manufacturer's warranty.
Part # 267-764
  • Mono block subwoofer amplifier
  • Variable subsonic filter 15~40 Hz (24 dB/octave)
  • Variable Low pass Filter 50~150Hz (24 dB/octave)
  • Remote bass level control
  • One-year manufacturer's warranty
PYLE amplifiers are designed with the lastest technology available, incorporating a Dc to Dc switching power supply, which provides headroom for even the most demanding peaks and dynamic range found on modern CD's and recordings.
Specifications: • Power output: 600 watts RMS x 1 (4 ohm load), 1,800 watts max x 1 (2 ohm load), 3,600 watts max x 1 (1.3 ohm load) • 1 ohm stable • Frequency response: 15-150 Hz • Variable low pass crossover: 50~150 Hz (24 dB/octave) • Variable subsonic filter: 15~40 Hz (24 dB/octave) • Total Harmonic Distortion (THD): < 0.1% • Signal to noise ratio (S/N): > 90 dB • Phase control: 0~180° • One-year manufacturer's warranty • Dimensions: 12-11/16" L x 8-5/8" W x 2-1/4" H.
  • Input TypeRCA Line Level
  • RMS Power Output (Per Channel 4 Ohms)600 Watts
  • Special Features2 ohm Stable,Preamp Outputs,1 ohm Stable
  • Output Channels1
  • BrandPyle Audio
  • ModelPLAD3300D
  • Part Number267-764
  • UPC068888873314
  • Product CategoryCar Amplifiers
    (2 Reviews)
  • Weight14.67 lbs.
View similar products to the Pyle PLAD3300D 1x3600W (1.3 ohm) Digital Monoblock Amplifier
in the Car Amplifiers product category.
