310-2098_ALT_0
310-2098_ALT_1
Pyle PHIW71 7.1 Home Theater Decora Type Speaker Wall Plate
Brand:| Model: PHIW71
The PHIW71 HDMI wall plate provides wall mounted wire connection for up to seven speakers to your stereo system with 14 gold plate terminals. With an in-wall speaker to amplifier connection, this wall plate is ready for the ultimate home theater set-up.
  • 7 speaker wall mount clean wire connection
  • Banana plug compatible
  • Dual sub-woofer RCA line-level connection
  • Mounts to standard electrical box
  • Attractive decora style white wall plate
  • One year manufacturer's warranty
310-2098
Weight: 0.7 lbs.
IN STOCK
List Price$66.99
You Save46%
$36.20
Part # 310-2098
  • BrandPyle Audio
  • ModelPHIW71
  • Part Number310-2098
  • UPC688888924450
  • Product CategoryHome Theater Pre-Configured Wall Plates
    (1 Reviews)
  • Weight0.7 lbs.
View similar products to the Pyle PHIW71 7.1 Home Theater Decora Type Speaker Wall Plate
in the Home Theater Pre-Configured Wall Plates product category.
Pyle PHIW71 7.1 Home Theater Decora Type Speaker Wall Plate is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from Convenient Package for clean wiring that works.This wall plate looks great and works as intended. My only grief with installing it was the fact that the individual connectors are installed in the plate without any regard to the location of the set screws in back which hold your wires. As assembled it would be impossible to get your screwdriver on every set screw. This was quickly remedied by loosening the nut on each connector and rotating it to one of the six possible orientations (which still isn't perfect for the connectors in the middle, but good enough).As with any screw tight connection on stranded wire, you must retighten the screws after a relaxation period (a few minutes) in order for the connections to remain tight, otherwise you risk the connections coming loose after installation into the wall. Or, as others have mentioned, you could solder the wires into the connectors, but its not absolutely necessary.
Date published: 2014-10-13
  • 2015-03-03T06:20CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_310-2098, PRD, sort_mostRecent
what is the best way to connect the speaker wire to the back of the wall plate?
Asked by: verds
Soldering is recommended unless you want to be taking it all apart next year to see why one speaker does not work. At least it reduces the number of connections to check, or moves it to the last on the list. I solder all speaker-wires when I install wall or ceiling speakers or build speaker enclosures, too. I have had them fall off when using crimp lugs or posts/clips. Solder them.
Answered by: Fanden
Date published: 2013-09-04
  • 2015-03-03T07:40CST
  • loc_en_US, sid_310-2098, PRD, sort_recentQuestionsFirst
Customer projects that include: Pyle PHIW71 7.1 Home Theater Decora Type Speaker Wall Plate
