292-2578_ALT_0
Pyle PH810 1" Screw-On Radiation Horn
Brand:| Model: PH810
Pyle's screw on 1" horn is made of a durable ABS resin.
292-2578
Weight: 0.95 lbs.
IN STOCK
List Price$35.99
You Save51%
$17.78
Part # 292-2578
Specifications: • Nominal coverage angle (-6 dB): 90° H x 40° V • Cut-off frequency: 1,000 Hz • Throat diameter: 26 mm (1") • Mounting type: Standard 1-3/8"-18 UNEF • Dimensions: 9.6" H x 7.9" W x 6" D • One year manufacturer's warranty • Sold individually.
  • Mounting Type1-3/8"-18 TPI
  • Entry / Throat Diameter1"
  • ConstructionABS
  • BrandPyle Audio
  • ModelPH810
  • Part Number292-2578
  • UPC068888886222
  • Product CategoryHorns & Waveguides
  • Weight0.95 lbs.
View similar products to the Pyle PH810 1" Screw-On Radiation Horn
in the Horns & Waveguides product category.
I guess I posted my question in the wrong place. This is a follow up question to the one I had earlier. Are the dimensions indicated Correct in relation to the coverage angle of  90 degrees Horizontal and 40 degrees Vertical?
Asked by: BoyP
Yes, with the horn laying horizontally the coverage will be 90 x 40.
Date published: 2014-09-17
Just want to verify that the dimensions indicated in the specifications are correct. Are the Height and Width of this item not interchanged?
Asked by: BoyP
The dimensions are accurate, although the picture is turned 90 degrees based on them. The horn can be oriented in either position.
Date published: 2014-09-15
Is this what is referred to as constant directivity or "waveguide"?
Asked by: figure8
No, the presence of the angles between sections of the horn from throat to mouth make this a "diffraction" horn.The QSC is the best example of a waveguide that PE carries:http://www.parts-express.com/pe/showdetl.cfm?Partnumber=245-625
Answered by: EdLIII
What are the cutout dimensions?
Asked by: vance
The cutout for this item should 7-7/8" x 6-1/2".
Answered by: RussR
Date published: 2011-09-21
  • 2015-01-31T02:20CST
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_292-2578, PRD, sort_recentQuestionsFirst
Customer projects that include: Pyle PH810 1" Screw-On Radiation Horn
Manuals / Resources
Need Help?
Customers Also Bought
