292-2572_ALT_0
Pyle PH612 1" Screw-On Constant Radiation Horn
Brand:| Model: PH612
Pyle's screw on 1" horn is made of a durable ABS resin.
292-2572
Weight: 1.27 lbs.
OUT OF STOCK
Due In: 2/6/2015
List Price$35.99
You Save60%
$14.39
Buy 4-up$11.33
Part # 292-2572
Specifications: • Nominal coverage angle (-6 dB): 90° H x 40° V • Cut-off frequency: 1,000 Hz • Throat diameter: 26 mm (1") • Mounting type: Zinc screw insert 1-3/8"-18 UNEF • Dimensions: 6.4" H x 11.9" W x 4.4" D • One year manufacturer's warranty • Sold individually.
  • Mounting Type1-3/8"-18 TPI
  • Entry / Throat Diameter1"
  • ConstructionABS
  • BrandPyle Audio
  • ModelPH612
  • Part Number292-2572
  • UPC068888886260
  • Product CategoryHorns & Waveguides
    (10 Reviews)
  • Weight1.27 lbs.
View similar products to the Pyle PH612 1" Screw-On Constant Radiation Horn
in the Horns & Waveguides product category.
Pyle PH612 1" Screw-On Constant Radiation Horn is rated 4.6 out of 5 by 10.
Rated 4 out of 5 by from Solid dealJust purchased these to pair with Selenium d220ti s.The build quality is quite good and mated to the CDs very easily and securely. Rigid enough that to date I have not found there to be any ringing. Well worth the price.
Date published: 2014-08-12
Rated 5 out of 5 by from Super Waveguide that "places" the sound!I use this waveguide with the Selenium D220Ti driver to Econowave my old W60 Wharfdales, and the sound is amazing! I previously tried to upgrade the Wharfies with the exponential horns and drivers that came with my vintage EV Eliminator cabinets, but they were so "honky" it was pathetic. These waveguides truly are different and they "place" the sound rather than project it, in a way that you have to hear to believe! The 90˚h x 40˚v directivity is perfect for typical rooms when placed in the corners of the room near head height where the axes of the speakers cross just in front of your listening "sweet spot". And you can't beat the price!
Date published: 2013-08-10
Rated 5 out of 5 by from Cheap & GoodA nice Waveguide for the price. It's not as smooth as Dayton's H07E Elliptical Waveguide but it's perfectly acceptable. The advantage is it can cross lower at 1,800Hz whereas the H07E is higher at 2,250Hz. Also, it has a wider horizontal dispersion.
Date published: 2013-01-12
Rated 4 out of 5 by from Outperforms many more expensive hornsI have investigated and experimented with a lot of horns, waveguide-style horns, and waveguides. At anywhere near its price range, this is the best I've found. I use it in several commercial products.
Date published: 2010-09-10
Rated 4 out of 5 by from for the priceHard to beat for the price....IF one tightens down a bit too hard, or tries to "fit" to an irregular surface.... it is cheap plastic. IF I could find one made out of nylon (or some other less brittle material).... I would pay more.On the plus side... it does have a brass insert instead of plastic threads...
Date published: 2010-02-05
Rated 5 out of 5 by from Excellent Horn!Ever wonder why this horn is always out of stock?Blame it on Zilch & jackgiff..Installed in a PE trap cab 245-32512" Eminence Cannabis Rex 16 ohm drivers for the midbass, Pyle PH612 horn with B&C BDE10-8 1" Mylar Horn Driver 8 Ohm 2-Bolt and Selenium throat adapter #264-323 using jackgiff's Econowave hi-sensitivity crossover from AudioKarmas site. Sealed cabinet for use with a subwoofer. Stuffed with fiberglass and well braced with 3/4" oak dowels. Equals Great Sound.
Date published: 2009-12-09
  • 2015-01-29T19:05CST
  • co_hasreviews, tv_0, tr_10
  • loc_en_US, sid_292-2572, PRD, sort_mostRecent
Customer projects that include: Pyle PH612 1" Screw-On Constant Radiation Horn
Discussions in our TechTalk Forum that include: Pyle PH612 1" Screw-On Constant Radiation Horn
