Pyle PEA6000 6000 Watt Stereo Power Amplifier
Brand:|Model: PEA6000|Part # 248-4346
The PEA6000 power amplifier features a peak output power of 6,000 watts. Has two channels stereo or bridge (mono) output with an independent volume control for each of the two channels.
  • Balanced XLR and 1/4" TRS inputs
  • High speed cooling fan
  • Lowest noise - smooth operation
  • Signal and clip LED indicators for protection and performance
  • Speakon-binding post speaker terminals
  • Thermal and overload protection
Specifications: • Power output: 520 watts RMS (Stereo 8 ohm)/ 800 watts RMS (Stereo 4 ohm)/ 2,000 watts (Bridged, 8 ohm)/ 6,000 watts peak • Distortion (typical): Less than 0.08% • Input sensitivity: 0.775V, 1V, 1.4V (Adjustable) • Impedance: Unbalanced > 10K ohm; Balanced > 20K ohm • S/N ratio: > 103 dB • Frequency response: 20 Hz-20 kHz, +0/-0 • Damping factor: > 220 • Cross talk: < -78 db @ 8 ohm • Power supply: 115V-60 Hz • Dimensions: 3.5" H x 19" W x 15.9" D.
  • Power Output (RMS Per Channel @ 8 ohms)520 Watts
  • Output Channels2
  • Weight Range40 to 49 lbs.
  • BrandPyle Audio
  • ModelPEA6000
  • Part Number248-4346
  • UPC068888904148
  • Weight41.34 lbs.
View similar products to the Pyle PEA6000 6000 Watt Stereo Power Amplifier
