248-4006_ALT_0
248-4006_ALT_1
248-4006_ALT_2
248-4006_ALT_3
248-4006_ALT_4
248-4006_ALT_5
248-4006_ALT_6
Pyle PDWM2500 Dual VHF Wireless Microphone System
Brand:|Model: PDWM2500|Part # 248-4006
Pyle Pro's PDWM2500 wireless microphone system has an operating frequency of VHF 160-270 MHz with a 240 ft. operating range.
- Order Soon - Only 3 Left In StockMore Due In February 12, 2016
List Price$128.99
You Save61%
$49.80
Part # 248-4006
  • Mute switch
  • Power and low battery LED indicators
  • Dual RF indicators
  • Dual AF level meters
  • Dual volume controls
  • 1/4" individual and mixed output
  • One year manufacturer's warranty
Pyle Pro's PDWM2500 wireless microphone system has an operating frequency of 160-270 MHz with a 240 ft. operating range. Features a power on/off switch, dual RF indicators, and dual AF level meters. Includes two handheld microphones, two 9V batteries, and a 1/4" audio cable.
Overall system specifications: • Oscillation mode: Quartz controlled • Carrier Frequency Range: VHF 160-270 MHz • Frequency stability: 30 ppm • Modulation mode: FM • Max deviation: ± 75 kHz • Dynamic range: >100 dB • S/N >60 dB • T.H.D: <0.5% • Frequency response: 80 Hz~20 kHz at ± 3 dB • Operating range: Up to 240 ft • Operating temperature: -20~50°C • Dimensions: 1.5" H x 7.75" W x 5.30" D.
Receiver specifications: • Sensitivity: 6 dB V at S/N>20 dB • Image rejection: >50 dB • De-emphasis: 50 µ s • Audio output level: 1V p-p • Audio output Impedance: 600 ohms • Power supply: DC 12V/200mA • Power dissipation: <800mW.
Transmitter specifications: • Mike capsule: Dynamic microphone • Pre-emphasis: 50 µs • Antenna: Built-in housing • RF output power: <10mW • Spurious emission: >40 dB • Battery: one 9V battery • Power dissipation: <250mW.
  • Frequency BandVHF
  • BrandPyle Audio
  • ModelPDWM2500
  • Part Number248-4006
  • UPC068888879255
  • Product CategoryHandheld Wireless Systems
    (4 Reviews)
  • Weight3.35 lbs.
View similar products to the Pyle PDWM2500 Dual VHF Wireless Microphone System
in the Handheld Wireless Systems product category.
Pyle PDWM2500 Dual VHF Wireless Microphone System is rated 5.0 out of 5 by 4.
Rated 5 out of 5 by from Wireless MicThe system was easy to use straight out of the box once I switched the voltage output to 120V instead of 220V on the power supply. It took a few seconds to figure out why it wouldn't power up. The other thing I noticed was I had to turn up the gain on the mixer board quite a bit over where I had it set for other microphones.
Date published: 2015-10-19
Rated 5 out of 5 by from Works awesomeI bought these for a 2 level bingo hall. Main board and caller upstairs, but we need to communicate between floors (Poured concrete) and have the sound coming through all speakers in the hall. Great clarity, great price. Couldn't be happier. I didn't think they would work, but decided to gamble.
Date published: 2014-05-02
Rated 5 out of 5 by from Amazing performance for the price.I installed this unit in a Kingdom Hall of Jehovah's Witness's. They use the wireless microphones for comments from the audience. Once they were set up and adjusted properly they worked flawlessly. Clear and accurate sound reproduction. I took one mic outside in the parking lot. At 50 feet from the receiver and transmitting through two walls the audio was clear. No hiss, crackle or buzz. Very good value for the money. I gave a top rating because for the money spent , using them for audience comments you do not need anything else.
Date published: 2014-01-24
Rated 5 out of 5 by from Excellent MicrophonesI purchased this set to replace an old worn out wireless set that I've had for over 14 years. The price was right but I admit I was skeptical on the performance. To my surprise, they worked great. I used them for a wedding that I was DJing the wedding music and reception. I'm glad I took a chance on this set.
Date published: 2012-04-04
  • 2016-02-11T06:40CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_248-4006, PRD, sort_mostRecent
"MattP  · 26 minutes ago   Other than batteries and the necessary cables to connect this to your system, everything is here that you need."  The system would consist of what? Sorry for my ignorance. We have at our Senior living facility a Peavey system.
Asked by: wjb1tex
Date published: 2016-01-18
As a non Techie is this everything required ? Or is there another piece of equipment needed ?
Asked by: wjb1tex
do carry the ac/dc power adaptor
Asked by: Vero1977
Without knowing the plug size I cannot guarantee this will fit, but the power and current will match:http://www.parts-express.com/panasonic-kx-a11-12-vdc-500ma-ac-adapter-55-x-21mm-center-%28-%29--129-005
Date published: 2015-01-14
Can you add wireless clip on or headset?
Asked by: Lliigman
Unfortunately this system is all in one, you cannot add or swap a microphone for another type.
Date published: 2014-09-15
Are these plastic or metal bodied mics?
Asked by: EMIC
These microphones have plastic bodies.
Date published: 2014-09-02
What adapter do I need to get the output to RCA inputs on a TV etc.?
Asked by: papaw
Left & right outputs on the rear of this receiver are1/4". You only need adaptor plugs. See below.
Answered by: Joe from San Francisco
Date published: 2013-10-03
  • 2016-02-11T07:39CST
  • co_hasquestionsanswers, tq_6
  • loc_en_US, sid_248-4006, PRD, sort_recentQuestionsFirst
