Pyle PDBT19 3.75" Aluminum Bullet Titanium Horn Tweeter Pr
Pyle PDBT19 3.75" Aluminum Bullet Titanium Horn Tweeter Pair
Brand:|Model: PDBT19|Part # 292-2606
Pyle Pro PDBT19 3.75" aluminum horn tweeter has a 1" high temperature Kapton voice coil.
List Price$44.99
You Save70%
$13.60
Part # 292-2606
  • 3.75" Aluminum horn
  • 1" Super tweeter
  • 1" High temperature Kapton voice coil
  • Ferro fluid enhanced voice coil
  • Mylar crossover capacitor included
Pyle Pro PDBT19 3.75" aluminum horn tweeter has a 1" high temperature Kapton voice coil. Features a Ferro fluid enhanced voice coil and an included mylar crossover capacitor. Sold in pairs.
Specifications: • Power handling: 150 watts RMS/300 watts peak • Sensitivity: 98 dB • Frequency response: 2 kHz - 25 kHz • Impedance: 4-8 ohms • Magnet structure: 20 oz. • Dimensions: 3.75" Diameter - 2" Mounting depth.
  • Diaphragm MaterialTitanium
  • Impedance4 ohms
  • Power Handling (RMS)150 Watts
  • BrandPyle Audio
  • ModelPDBT19
  • Part Number292-2606
  • UPC068888896610
  • Product CategoryHorn Loaded Bullet Tweeters
  • Unit of MeasurePR
    (3 Reviews)
  • Weight2.6 lbs.
View similar products to the Pyle PDBT19 3.75" Aluminum Bullet Titanium Horn Tweeter Pair
in the Horn Loaded Bullet Tweeters product category.
Pyle PDBT19 3.75" Aluminum Bullet Titanium Horn Tweeter Pair is rated 4.6667 out of 5 by 3.
Rated 4 out of 5 by from better than expectedpurchased a pair for a fisher ds 153 floor monitors that were bought for 14.00 a pair .both tweeters were blown. the pyles sounded very good considering the cheap price. I would not put these into a book shelf speakers ,they would be to bright . the bigger the enclose the better. remember they will sound tinny when they are brand new .broke them in for about 6 hours ,then the really started opening up.prucution drums snar symbol sounded detailed open and airy. the the mid s and woffer drivers blended very well together with these pyles.one friend said that the sounded a little holographic if you are in the sweet spot.for the price you cant beat them.if you have an old pair o speakers in the attic or basement for storage,break them out and replace the original tweets ,you wont be disappointed,unless you want super high end tweets these will do the trick.IM buying another pair pair of epi monitors. enjoy!
Date published: 2015-01-14
Rated 5 out of 5 by from Great all around tweeterI ordered two sets of these & installed them in two different sets of speakers. In each case these easily outperformed the original tweeters. I replaced tweeters in philips front channel speakers & in AR 707 floor monitors. I am now enjoying louder crisper highs from both sets of speakers with no increase in amplifier power. I am very pleased with the appearance & performance of these.
Date published: 2014-04-22
Rated 5 out of 5 by from PylitheanPDBT-19 With HI-VI M5N and 5.25" Aluminum 450 Hz Low pass Andrew Jones Style cabnet buy Jaton. Crossover are 2500 for the Pyle PDBT-19 and 3500 Hz HI-VI M5N makes the center crossover 3000 HZ. Best sounding speakers I ever had. Center are Yamaha 4 - 4" with 1" Titanium Samsung. I put in. 10" POLK woofer.
Date published: 2014-03-19
  • 2016-02-08T06:19CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_292-2606, PRD, sort_mostRecent
What are the capacitor values used and sold with these tweeters?
Asked by: DoItYourself
These tweeters come with 3.3 uF capacitors.
Date published: 2015-08-04
Is this 8 ohm.
Asked by: viper50
These tweeters are 4 ohm each.
Date published: 2015-07-27
What is the bolt pattern size on this horn?
Asked by: Brian79
The mounting holes are 3-1/4" apart on center.
Date published: 2015-07-13
I have a couple of questions: In the product details it says " sold in pairs", but in the answers it said one in the package. Can you clarify how many indeed included in this price? Can this tweeter be used to replace one with 8 ohm impedance?
Asked by: Jmz12
These are sold in pairs. I would only recommend replacing an 8 ohm tweeter with a 4 ohm model if the crossover is modified to work properly with a 4 ohm load.
Date published: 2014-12-02
What is the lowest frequency this tweeter can be crossed over using a second order passive crossover? Would like to use these in a 2-way MTM with 10" woofers (PA255-8), and would like a low Xover freq to limit beaming from the woofers.
Asked by: Doug913
I would not recommend crossing this tweeter any lower than 4,500 Hz second order.
Date published: 2014-10-21
Will I need a separate crossover?  or is the included capacitor enough?
Asked by: eln1ce
These do not require a separate crossover if the included capacitor is used.
Date published: 2014-09-04
  • 2016-02-08T07:08CST
  • co_hasquestionsanswers, tq_10
  • loc_en_US, sid_292-2606, PRD, sort_recentQuestionsFirst
