248-4264_ALT_0
Pyle PCM60A 100 Watt Power Amplifier w/25 & 70 Volt Output
Brand:|Model: PCM60A|Part # 248-4264
This 100 watt power amplifier by Pyle provides all the juice you need for your 25V or 70V PA speaker.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$315.99
You Save52%
$153.00
Buy 4+$145.35
Part # 248-4264
  • Power On/Off switch & LED indicator
  • Bass and treble tone controls
  • Contour control on/off loudness switch
  • AUX RCA output
  • AUX 1/AUX2/AUX 3 RCA Input
  • MIC 1/MIC 2/MIC 3 terminals (MIC 1 Auto talkover)
  • TEL/PAGING terminals
Connect up two mics/aux inputs using the rear terminals, XLR input, and RCA jacks. Mic-1 has an auto talkover so you can easily cancel the other inputs. Each input has an independent gain control, and you can also adjust the tone of the sound using the rotary treble and bass faders. Connect your speakers using the rear terminals. This unit is also equipped with an unswitched 500 watt max grounded power outlet on the back. Also capable of music-on-hold. Includes a replaceable fuse and detachable AC power input. Runs on 110 or 220V.
Specifications: • Max output power: 100 watts x 1 • THD: ≤1% @ 1 kHz • Frequency response (±3 dB): 50 Hz to 15 kHz • Speaker output: 4 ohm, 8 ohm, and 16 ohm; 25V and 70V line outputs • Aux output: 600 ohm 1V • Power requirement: 120 VAC, 60 Hz; 230 VAC, 50 Hz • Dimensions: 16.93" W x 3.46" H x 10.51" D (430 x 88 x 267 mm) • Weight: 14.88 lbs. (6.75 kg).
  • Power Output (RMS @ 70V)101W to 200W
  • Weight Range10 to 19 lbs.
  • BrandPyle Audio
  • ModelPCM60A
  • Part Number248-4264
  • UPC068888896887
  • Product CategoryPaging & Commercial 70V Mixer-Amplifiers
    (2 Reviews)
  • Weight17.45 lbs.
View similar products to the Pyle PCM60A 100 Watt Power Amplifier w/25 & 70 Volt Output
in the Paging & Commercial 70V Mixer-Amplifiers product category.
Pyle PCM60A 100 Watt Power Amplifier w/25 & 70 Volt Output is rated 2.5 out of 5 by 2.
Rated 4 out of 5 by from Very reasonable for the moneyThe only cone I found so far is a lack of rack mount brackets but $15 shelf did the trick
Date published: 2013-06-21
Rated 1 out of 5 by from Don't go hereJust received (2) of these amps, both had transformers busted loose and floating around in the chassis, along with plastic shrapnel in the box. Must be a bad design, there was no exterior damage to the shipping box or the interior box. On the other hand, Parts Express did a great job of getting replacements to me...Good job guys!!
Date published: 0003-06-22
  • 2016-02-06T07:08CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_248-4264, PRD, sort_mostRecent
I am looking for an amplifier for restaurant music I have four speakers each is 8 omhs in total its 32 omhs because they are connected in serie so what amplifier do you recommend I use that can be easy to install
Asked by: allsafety
I would recommend re-wiring the speakers so they all have individual home runs back to the amplifier. Something like the Sherwood below will power four 8 ohm speakers separately without issue.http://www.parts-express.com/sherwood-rx-5502-multi-room-stereo-receiver--252-120
Date published: 2014-03-27
Do you have a speaker switch that handle 70v speakers powered by the Pyle 100watt 70 volt amp?
Asked by: L DRIES
Any switch with selectable impedance protection will work, you just have to make sure that impedance protection is turned off.
Date published: 2012-10-15
  • 2016-02-06T08:21CST
  • loc_en_US, sid_248-4264, PRD, sort_recentQuestionsFirst
