Pyle PCAU11 Mini 2x15 Watt Stereo Power Amplifier w/USB
Brand:|Model: PCAU11|Part # 310-2216
Pyle PCAU11 mini power amplifier has an output power of 15 watts x 2 @ 4 ohms.
Part # 310-2216
  • Power on LED indicator
  • Master volume control
  • RCA cable L/R input
  • Four push type speaker L/R terminals
  • 110/220 Voltage selector
Pyle PCAU11 mini power amplifier has an output power of 15 watts x 2 @ 4 ohms. Compatible with USB memory sticks and MP3 files. Features a USB reader function.
Specifications: • Output power, 2 channels driven: 4 ohms 1 kHz, 1% THD 3 watts x 2; 4 ohms 1 kHz, 10% THD, 4 watts x 2 • Max power: 15 watts x 2 • Total harmonic distortion (1 kHz rated power): 0.3% • Input sensitivity (1 kHz, 4 ohm rated power): Line 150mV; USB 150mV • Frequency response: 20 Hz - 20 kHz • S/N ratio (1 kHz, 4 ohm rated power): Line 80 dB; USB 80 dB • Power requirement: 120V AC 60 Hz/230V AC 50 Hz • Power fuse: 1A, 250V fast-acting, 5 x 20 mm • Dimensions: 5.61" W x 2.17" H x 4.21" D (142.6 x 55 x 107 mm) • Weight: 2.38 lbs. (1.08 kg).
  • Special FeaturesUSB Connectivity
  • BrandPyle Audio
  • ModelPCAU11
  • Part Number310-2216
  • UPC068888901505
  • Product CategoryHome Audio Amplifiers
    (1 Reviews)
  • Weight2.56 lbs.
View similar products to the Pyle PCAU11 Mini 2x15 Watt Stereo Power Amplifier w/USB
in the Home Audio Amplifiers product category.
