303-506_ALT_0
303-506_ALT_1
Pure Acoustics Supernova C Center Channel Speaker Black
Brand:| Model: Supernova C
Product Video
Delivering both impact and realism in conjunction with superb, modern aesthetics, the Pure Acoustics Supernova-C supplies the imaging and clarity demanded by a high-quality 5.1 home theater system.
A restocked/refurbished, or Open Box unit of the product is available -- see it now
  • 2-way center channel speaker designed for home theater use
  • Carefully selected and optimized components provide startling realism
  • Magnetically shielded components prevent interference
  • Dual 5-1/4" midrange drivers provide clear, dynamic reproduction
  • Oil-cooled 1" silk dome tweeter w/neodymium magnet for clear HF response
  • Sophisticated crossover network for smooth response and driver protection
  • Modern high-gloss black front panel
303-506
Weight: 11.55 lbs.
OUT OF STOCK
Due In: 1/30/2015
List Price$259.00
You Save65%
$89.98
Part # 303-506
The center channel speaker of the Supernova Series, the Pure Acoustics Supernova-C utilizes a two-way crossover design, well-balanced cone drivers, and PPCA technology dome tweeters to make your home cinema experience come alive.
Two 5" midrange speakers flank an oil-cooled 1" silk dome tweeter, the combination of which provides superior dialogue reproduction—clearly and energetically. The Supernova-C is magnetically shielded to prevent interference when it is placed near a sensitive TV monitor. Sold individually.
Specifications: • Power handling: 150 watts RMS, 250 watts peak • Frequency response: 60-20,000 Hz • Sensitivity: 89 dB @ 1W/1m (+/-3db) • Impedance: 8 ohms nominal • Dimensions: 6.3" H x 18.1" W x 7.9" D.
  • Input Rating4 ohm
  • Woofer Diameter5"
  • Configuration2-way (MTM)
  • ColorGloss Black
  • BrandPure Acoustics
  • ModelSupernova C
  • Part Number303-506
  • UPC183864000680
  • Product CategoryCenter Channel Speakers
    (5 Reviews)
  • Weight11.55 lbs.
View similar products to the Pure Acoustics Supernova C Center Channel Speaker Black
in the Center Channel Speakers product category.
Pure Acoustics Supernova C Center Channel Speaker Black is rated 4.2 out of 5 by 5.
Rated 3 out of 5 by from Don't botherI have been in the process of upgrading my home theater speakers. I had recently purchased a Cerwin Vega XLs6c. It's fairly large and I thought I would try the Pure Acoustics since it had mostly great reviews. It's smaller and hopefully sounds as good.Not even close. The Pure Acoustic didn't exceed the cheap Onkyo center I bought years ago. It's trebly and nasally. I returned it. It was a $30 experiment (shipping back and forth) that I lost on.
Date published: 2014-03-13
Rated 5 out of 5 by from Great Speaker!This was purchased to replace/upgrade my surround system speakers. As far as I'm concerned this speaker sounds as good or better than much pricier units. Very happy with the performance of this speaker, it has exceeded my expectations.
Date published: 2014-01-24
Rated 5 out of 5 by from great speaker!Great Speaker, great performance at a very good price! I bought 2 of these and will recommend for anyone! Also lookingAt the supernova 8 f tower speaker.
Date published: 2013-05-02
Rated 4 out of 5 by from Central Center ChannelAm piecing together my first 5.1 system after building my own Transmission Line main fronts from a prior Parts Express purchase. Connected this to my Onkyo, lowered its Center output so it wouldn't overly dominate, and cranked it up. Haven't performed any acoustical tests but am satisfied. It's in the living room so must look good but unobtrusive. Placed on a raised dais of a brick fireplace so is effective. Pure Acoustics is on my list as I extend my systems.
Date published: 2012-05-27
Rated 4 out of 5 by from Fit my needs perfectlyI finally decided to stop using my TV as the center channel and instead go with a dedicated center channel. The height I had to work with was limited to 6.5 inches and I thought I was going to need to make my own speaker. Then I found this one, and for the price knew I couldn't make my own. I'm very pleased with the design and performance of this unit. I used the microphone with my receiver to re-tune my speaker set up and the 5.1 system sounds MUCH better than it did with the TV as the center channel.
Date published: 2012-04-29
Impedance: 4 ohms nominal
I just purchased this unit with the matching bookshelf speaking, I am confused about the Impedance: 4 ohms nominal. I also two have 8 ohms ceiling speakers, can these be run on the same receiver?
Asked by: MCA1
As long as the receiver will safely run a 4 ohm load, you can mis-match impedances.
Date published: 2013-02-18
Looking at building a home theater system around the supernova series. What 5.1 or 7.1 receivers can handle the 4 ohm load?
Asked by: WRathbone
At this time, we do not carry a 5.1 or 7.1 receiver that is stable to 4Ω.
Answered by: RussR
Date published: 2012-02-15
Can i use this speaker with my other speakers and receiver?
Current speakers and receiver (ONKYO TX-SR506) are rated 8 ohms. Center speaker in question is rated 4 ohms. Thanks!
Asked by: Rikkito
It could lead to some issues in the future if you play that center channel which is a 4 ohm load on an 8 ohm load minimum amp. I would suggest you not do that.
Answered by: paragv
Date published: 2012-11-27
Videos
Customer projects that include: Pure Acoustics Supernova C Center Channel Speaker Black
