303-510_ALT_0
303-510_ALT_1
Pure Acoustics Noble II C Center Channel Speaker Black
Brand:| Model: Noble II C
Product Video
The Pure Acoustics NobleII-C center channel speaker's clean, modern design combines with a high-tech crossover, advanced drivers, and gold-plated terminals housed in a beautifully finished piano-black enclosure.
  • 2-way speaker system designed for home theater center channel applications
  • Oil-cooled 1" silk dome tweeter w/neodymium magnet delivers pin-drop clarity
  • Dual 4" poly-injected woofers engineered for extreme clarity and dynamic range
  • Magnetic shielding eliminates interference when placed near a TV monitor
  • Contemporary black high-gloss piano finish blends with surroundings
303-510
Weight: 7.6 lbs.
IN STOCK
List Price$279.00
You Save60%
$110.98
Part # 303-510
The Pure Acoustics Noble II-C center speaker's driver components are similar to those of the front speakers in the series, complementing them and creating a harmonious soundstage for a seamless home cinema experience.
This magnetically shielded speaker is a 2-way design with dual 4" poly-injected cone drivers and an oil-cooled 1" silk dome neodymium tweeter. Gold-plated terminals ensure uncompromised conductivity. The Noble II-C features a curved, high-gloss piano finish that makes it an attractive companion to all plasma television sets. Sold individually.
Specifications: • Power handling: 150 watts RMS, 225 watts peak • Frequency response: 60-20,000 Hz • Sensitivity: 87 dB @ 1W/1m (+/-3db) • Impedance: 4 ohms nominal • Dimensions: 5.5" H x 15.75" W x 5.5" D.
  • Input Rating4 ohm
  • Woofer Diameter4"
  • Configuration2-way (MTM)
  • ColorBlack
  • BrandPure Acoustics
  • ModelNoble II C
  • Part Number303-510
  • UPC183864000567
  • Product CategoryCenter Channel Speakers
    (1 Reviews)
  • Weight7.6 lbs.
View similar products to the Pure Acoustics Noble II C Center Channel Speaker Black
in the Center Channel Speakers product category.
Pure Acoustics Noble II C Center Channel Speaker Black is rated 1.0 out of 5 by 1.
Rated 1 out of 5 by from Poor Value for the MoneyI'll start this review by stating that I've never heard of Pure Acoustics and should have known better. I bought this simply because the stated specs seemed decent, and it was a perfect fit dimension wise for an rather small space that was available in my home theater cabinet.After hooking it up, it sounded REALLY bad. Really, really bad. Being the curious type I am, I removed one of the woofers to expose the wiring. At first I was shocked to find there is no "high-tech" crossover in this unit at all. There is a single capacitor wired in series with the tweeter, the woofers are wired directly to the rear terminals. I know that this is a simple form of crossover used in cheap speakers, but never expected this from something as advertised as a "high-tech" crossover, this is literally as low tech as you can get. The reason they sounded so horrible is that one lead of the cap is soldered directly to the terminal block, and the other lead soldered to the tweeter wire had bent over and was touching the other terminal block lead. I pulled it away, and the speaker sounded better. Better, but not good.The finish is decent, that's about the only nice thing I can say about this unit.
Date published: 2013-03-23
  • 2015-03-31T07:27CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_303-510, PRD, sort_mostRecent
Videos
Customer projects that include: Pure Acoustics Noble II C Center Channel Speaker Black
