PRV Audio WG 500 1.4" 140 degree W Line Array Waveguide 4-Bolt
Brand:|Model: WG 500|Part # 294-2840
Use the PRV Audio WG 500 to create professional audio line arrays with 1.4" exit compression drivers. 140° horizontal coverage with minimal vertical dispersion and acoustic loading down to 1 kHz.
List Price$65.78
You Save30%
$45.99
Part # 294-2840
  • 140° wide dispersion pattern with minimal vertical dispersion
  • Stackable design for tight grouping
  • 1.4" throat diameter
  • Lightweight aluminum construction
  • Acoustically loads compression drivers down to 1,000 Hz
PRV Audio's WG 500 lightweight aluminum horn is designed specifically for line array applications. The four-bolt flange is designed to mate to 1.4" compression drivers and offers a 140° horizontal coverage pattern with minimal vertical dispersion to increase output distance while acoustically loading a driver down to 1,000 Hz. Rear mount design calls for a 6" x 1" cabinet opening.
Specifications: • Horn type: Line array • Minimum frequency: 1,000 Hz • Nominal dispersion: 140° H x 15° V • Throat diameter: 1.4" • Mounting type: 4-bolt, 1/4" diameter holes on a 4" diameter circle (fits standard 4-bolt 1.4" drivers) • Dimensions: 6-3/8" H x 5-3/16" W x 6-7/8" D • Cabinet cutout: 6" H x 1" W.
  • Mounting Type4-Bolt
  • Entry / Throat Diameter1.4"
  • ConstructionAluminum
  • BrandPRV Audio
  • ModelWG 500
  • Part Number294-2840
  • UPC799928733984
  • Product CategoryHorns & Waveguides
    (3 Reviews)
  • Weight3 lbs.
View similar products to the PRV Audio WG 500 1.4" 140 degree W Line Array Waveguide 4-Bolt
in the Horns & Waveguides product category.
PRV Audio WG 500 1.4" 140 degree W Line Array Waveguide 4-Bolt is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Quality horn in a small package medium throwI have these in a 3 way PA cabinet with PRV D280Ti driver and got exactly what I was looking for Compact wide angle horn and clear using 2- 8inch mids and 15 wooferthese are in my living room listening to Steely Dan I have 18db xover on them at 4KHZ
Date published: 2014-06-10
Rated 5 out of 5 by from A very good horn for a line array cabinet!!I loaded this horn with a PRV 1.4" D3240-Ti/16 in a cabinet with 2-10" drivers for a line array proto type. It performs very well. It is very smooth with exceptional highs up above 12k. Brings clarity and great imaging to the program material. Highly recommended!!!
Date published: 2013-03-05
Rated 5 out of 5 by from Waveguide Lens: "What you should know"This WG 500 is absolutely and unconditionally a gem!!HF horizontal coverage was excellent and rolled off smooth. it's vertical pattern was not specified, however, i am almost certain its 10 degrees, where it impressively cut-off as sharp as a razor.Tests were done quick by ear.I may update this post after properly analyzing with measurement software but feel is unnecessary...."what you should know"This is a specialty item for a specific application.please do not just purchase solely based on the AAA+++ review.comments are intended for users familiar with Waveguide lenses and their operating properties.Waveguide CONCEPT in brief and short :Waveguides spread high frequencies very wide in the horizontal plain and very,very, narrow in the vertical. (EX. 140, 120, 100 X 15 or 10 degrees);whereas,Constant Directive and Exponential horns vertical's coverage is a medium wide plain.(EX: 120, 100, 90 x 40 or 60 degrees).Comparing vertical coverage angles in degrees, you would need 3X as many waveguides for vertical coverage,, per side!!SO THEN WHY WAVEGUIDES?Waveguides very narrow vertical design increases HF throw ten fold!! this is most deal for concert sound and theatrical venues where focus, clarity, loudness and overall intelligibility is critical. waveguides achieve this like no-other.Getting the mid and lo frequency drivers to match it is the trick and the hard part.matching is achieved through complex cabinet design, driver choices, amplifier power, hardcore digital processing and vast knowledge in acoustics, phase, cabinet tuning, structural, and rigging laws to fly cabinets..Ive included pictures showing the WG 500 waveguides inside the hornand my vertical curvilinear line array design Model# 2821-16
Date published: 2012-11-06
  • 2016-02-10T06:33CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_294-2840, PRD, sort_mostRecent
Would this waveguide work with jbl 2445's?
Asked by: Birdseye
No, this waveguide will only work with 1.4" throat horns.
Date published: 2015-08-05
Would this work with the selenium d220 ti if I also buy a 4 bolt to tpi adapter.  Or would it only work with 1.4" drivers
Asked by: Pewpew
The adapter will not be tapered to work properly with a 1.4" throat. This horn lens is only designed to work with 1.4" drivers.
Date published: 2015-04-20
on your cabinets...did you build a "horn" in front of the prv wave guide or just use it as is and mount it to a fla baffle board?
Asked by: Cutter
These are designed to be used as is.
Date published: 2014-05-30
I see the WG 500 is rated for a 1Khz throat
Looking for a driver that handles 1.2Khz for this waveguide.Any thought out there?
Asked by: mnow21
This will be in the specifications for the drivers on our website. PRV makes a 1.4" driver that will likely be a perfect match for this horn.
Date published: 2013-02-20
What driver is best
What is the best driver to use with these?
Asked by: mnow21
Unfortunately I cannot say which is best, everybody has their own opinion on this. However, any 4 bolt 1.4" throat driver will work with it.
Date published: 2015-02-07
The specs only say "4 bolt" for mounting type . What is the spacing measurment ?
Asked by: Doc Ivo
This is for use with 4 bolt type horns with an industry standard 4" diameter mounting circle.
Date published: 2013-04-16
  • 2016-02-10T07:21CST
  • co_hasquestionsanswers, tq_7
  • loc_en_US, sid_294-2840, PRD, sort_recentQuestionsFirst
