PRV Audio WG 14-50 2" 45 x 45 Aluminum Waveguide 4-Bolt
Brand:|Model: WG 14-50|Part # 294-2843
Use the PRV Audio WG 14-50 exponential horn to create small professional audio or DJ speakers with 2" bolt-on compression drivers. 45° x 45° coverage is perfect for stage monitors where a tighter coverage pattern is needed.
Comparable Items In Stock:
Part # 294-2843
  • 45° x 45° dispersion pattern for personal stage monitors
  • 2" throat diameter with 4-bolt mounting pattern
  • Aluminum construction with exponential flare
  • Acoustically loads compression drivers down to 700 Hz
PRV Audio's WG 14-50 45° x 45° exponential horn is designed to project a controlled dispersion pattern, such as needed with personal stage monitors, over a long distance. Strong, lightweight aluminum construction is used to keep cabinets as light as possible for easy transport while supporting the weight of the compression driver. A standard 4-bolt flange is compatible with many 2" compression drivers. Acoustic loading is maintained down to 700 Hz.
Specifications: • Horn type: Exponential • Minimum frequency: 700 Hz • Nominal dispersion: 45° H x 45° V • Throat diameter: 2" • Mounting type: 4-bolt • Dimensions: 6.875" dia. (6.12" on the flats) x 5.25" D • Cabinet cutout: 4.75" dia.
  • Mounting Type4-Bolt
  • Entry / Throat Diameter2"
  • ConstructionAluminum
  • BrandPRV Audio
  • ModelWG 14-50
  • Part Number294-2843
  • UPC799928733946
  • Product CategoryHorns & Waveguides
  • Weight1.9 lbs.
View similar products to the PRV Audio WG 14-50 2" 45 x 45 Aluminum Waveguide 4-Bolt
in the Horns & Waveguides product category.
