PRV Audio WG 11-25 45 x 45 1" ABS Waveguide 1-3/8"-18 TPI
Brand:|Model: WG 11-25|Part # 294-2842
Use the PRV Audio WG 11-25 exponential horn to create small professional audio or DJ speakers with 1-3/8"-18 TPI screw-on compression drivers. 45° x 45° coverage is perfect for stage monitors where a tighter coverage pattern is needed.
List Price$6.28
You Save21%
$4.99
Part # 294-2842
  • 45° x 45° dispersion pattern for personal stage monitors
  • 1" throat diameter with 1-3/8"-18 TPI threads
  • Lightweight ABS construction with exponential flare
  • Acoustically loads compression drivers down to 1,200 Hz
PRV Audio's WG 11-25 45° x 45° exponential horn is designed to project a controlled dispersion pattern, such as needed with personal stage monitors, over a long distance. Durable ABS construction is used to keep cabinets as light as possible for easy transport. The standard 1-3/8"-18 TPI threading is compatible with many 1" compression drivers. Acoustic loading is maintained down to 1,200 Hz.
Specifications: • Horn type: Exponential • Minimum frequency: 1,200 Hz • Nominal dispersion: 45° H x 45° V • Throat diameter: 1" • Mounting type: 1-3/8"-18 TPI • Dimensions: 4.5" H x 4.5" W x 2.95" D • Cabinet cutout: 3.75" H x 3.75" W.
  • Mounting Type1-3/8"-18 TPI
  • Entry / Throat Diameter1"
  • ConstructionABS
  • BrandPRV Audio
  • ModelWG 11-25
  • Part Number294-2842
  • UPC799928733977
  • Product CategoryHorns & Waveguides
    (2 Reviews)
  • Weight0.2 lbs.
View similar products to the PRV Audio WG 11-25 45 x 45 1" ABS Waveguide 1-3/8"-18 TPI
in the Horns & Waveguides product category.
