294-2842_ALT_0
294-2842_ALT_1
PRV Audio WG 11-25 1" 60 x 60 ABS Waveguide 1-3/8"-18
Brand:| Model: WG 11-25
Use the PRV Audio WG 11-25 exponential horn to create small professional audio or DJ speakers with 1-3/8"-18 TPI screw-on compression drivers. 60° x 60° coverage is perfect for stage monitors where a tighter coverage pattern is needed.
  • 60° x 60° dispersion pattern for personal stage monitors
  • 1" throat diameter with 1-3/8"-18 TPI threads
  • Lightweight ABS construction with exponential flare
  • Acoustically loads compression drivers down to 1,200 Hz
294-2842
Weight: 0.2 lbs.
IN STOCK
List Price$6.48
You Save22%
$4.99
Part # 294-2842
PRV Audio's WG 11-25 60° x 60° exponential horn is designed to project a controlled dispersion pattern, such as needed with personal stage monitors, over a long distance. Durable ABS construction is used to keep cabinets as light as possible for easy transport. The standard 1-3/8"-18 TPI threading is compatible with many 1" compression drivers. Acoustic loading is maintained down to 1,200 Hz.
Specifications: • Horn type: Exponential • Minimum frequency: 1,200 Hz • Nominal dispersion: 60° H x 60° V • Throat diameter: 1" • Mounting type: 1-3/8"-18 TPI • Dimensions: 4.5" H x 4.5" W x 2.95" D • Cabinet cutout: 3.75" H x 3.75" W.
  • Mounting Type1-3/8"-18 TPI
  • Entry / Throat Diameter1"
  • ConstructionABS
  • BrandPRV Audio
  • ModelWG 11-25
  • Part Number294-2842
  • UPC799928733977
  • Product CategoryHorns & Waveguides
    (1 Reviews)
  • Weight0.2 lbs.
View similar products to the PRV Audio WG 11-25 1" 60 x 60 ABS Waveguide 1-3/8"-18
in the Horns & Waveguides product category.
PRV Audio WG 11-25 1" 60 x 60 ABS Waveguide 1-3/8"-18 is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from This horn has excellent high's.Yes, I am using this horn coupled to a Selenium D220TIhorn driver on my home system. This horn, in this combination,has the best high's I've ever heard in a home system, too.On other high quality tweeters, for example, cymbals soundvery similar if not the same from song to song and album to album. Not so with this tweeter. Each cymbal crash comesthrough pronounced, and vocal "t's," and "s's"are pure with no sibilance. I have this horn combo crossed-over at 1.9 KHz, and it does great. I've had other horn tweeter's and planar's, and I've heard quite a few speakers,and this tweeter is top notch, even for a home system.
Date published: 2013-05-28
can I use this one with PRV D250 PH-S
Asked by: jayson
Yes this will work with any 1-3/8" threaded driver although this horn is only good to about 1,200 Hz so it will be the limiting factor with a midrange type compression driver.
Date published: 2013-10-21
would this waveguide be compatiable with the Pyle PDS182 ?
Asked by: jukebox
Yes these two are perfectly compatible with each other.
Date published: 2013-05-15
Customer projects that include: PRV Audio WG 11-25 1" 60 x 60 ABS Waveguide 1-3/8"-18
