294-2818_ALT_0
PRV Audio TW600Ti High Power Titanium Bullet Super Tweeter 8 Ohm
Brand:|Model: TW600Ti|Part # 294-2818
Add crystal clear sparkle to any speaker with PRV Audio's TW600Ti titanium bullet super tweeter! With high frequency response up to 22,000 Hz and a sensitivity of 107 dB at 1W/1m, the TW600Ti can keep up with even the most demanding speaker systems. Flat sides allow for side by side mounting.
  • Kapton® former and ring-radiator titanium diaphragm adds sparkle to any speaker
  • Rear-mounted design for driver security, flat sides for side-by-side multiple driver arrays
  • Designed for ultra-high frequency use from 4,000-22,000 Hz
  • High 107 dB sensitivity and 100 watt RMS power handling
  • Includes capacitor for protection
PRV Audio's TW600Ti super tweeter (also referred to as a bullet tweeter) is designed to add high output, high frequency response to any speaker system. The titanium, ring-radiator diaphragm combines with the durable, yet light weight, Kapton® voice coil former for sensitivity levels of up to 107 dB from 4,000 to 22,000 Hz. Output is enhanced by the phase plug for a disperse coverage pattern and side by side mounting is facilitated by flat sides.
Not only does this driver look as good as it sounds, with a rear mount frame design to conceal the mounting tabs, it's also able to take a huge amount of power due to its 1.5" diameter copper voice coil. Up to 100 watts of power handling are on tap to keep up with the most demanding professional audio, high output home audio, and high SPL car audio systems. A capacitor is included for protection from damaging frequencies at high power. Mounting hardware included.
Specifications: • Power handling: 100 watts RMS with recommended crossover of 5,000 Hz, 12 dB/octave • Minimum recommended crossover point: 5,000 Hz • VCdia: 1.7" • Impedance: 8 ohms • Frequency response: 4,000-22,000 Hz • SPL: 107 dB 1W/1m • Dimensions (H x W x D): 4" x 4" x 2.55" • Weight: 1.67 lbs. • Replacement diaphragm available (please see Related Items).
  • Diaphragm MaterialTitanium
  • Impedance8 ohms
  • Power Handling (RMS)100 Watts
  • BrandPRV Audio
  • ModelTW600Ti
  • Part Number294-2818
  • UPC799928733915
  • Product CategoryHorn Loaded Bullet Tweeters
    (1 Reviews)
  • Weight3.1 lbs.
View similar products to the PRV Audio TW600Ti High Power Titanium Bullet Super Tweeter 8 Ohm
in the Horn Loaded Bullet Tweeters product category.
