PRV Audio TW450-Ti Titanium Bullet Super Tweeter 8 Ohm
Brand:|Model: TW450Ti|Part # 294-2820
The PRV Audio TW450-Ti titanium bullet super tweeter adds crystal clear sparkle to any speaker! With high frequency response up to 22,000 Hz and a sensitivity of 107 dB at 1W/1m, the TW450-Ti can keep up with even the most demanding speaker systems.
  • Kapton® former and ring-radiator titanium diaphragm adds sparkle to any speaker
  • Designed for ultra-high frequency use, 5,000-22,000 Hz
  • High 107 dB sensitivity keeps up with the highest efficiency mid and bass components
  • Includes 2.2 uF capacitor for protection
  • Rear-mount faceplate design for driver security and professional appearance
PRV Audio's TW450-Ti super tweeter (also referred to as a bullet tweeter) is designed to add high output, high frequency response to any speaker system. The ring-radiator titanium diaphragm combines with the durable, yet light weight, Kapton® voice coil former to achieve sensitivity levels of up to 107 dB from 3,000 to 22,000 Hz. Output is enhanced by the phase plug for a focused coverage pattern.
Not only does this driver look as good as it sounds, with a rear mount frame design to conceal the mounting tabs, it's also able to take a huge amount of power due to its 1.7" diameter copper voice coil. Up to 80 watts of power handling are on tap to keep up with the most demanding professional audio, high output home audio, and high SPL car audio systems. A 2.2 µF capacitor is included for protection from damage caused by lower frequencies at high power. Mounting hardware included.
Specifications: • Power handling: 80 watts RMS with recommended crossover of 5,000 Hz, 12 dB/octave • Minimum recommended crossover point: 5,000 Hz • VCdia: 1.7" • Impedance: 8 ohms • Frequency response: 3,000-22,000 Hz • SPL: 107 dB 1W/1m • Dimensions (H x W x D): 4.5" x 3.75" x 2.9" • Weight: 3.5 lbs. • Replacement diaphragm available (please see Related Items).
  • Diaphragm MaterialTitanium
  • Impedance8 ohms
  • Power Handling (RMS)80 Watts
  • BrandPRV Audio
  • ModelTW450Ti
  • Part Number294-2820
  • UPC799928733922
  • Product CategoryHorn Loaded Bullet Tweeters
    (4 Reviews)
  • Weight3.25 lbs.
View similar products to the PRV Audio TW450-Ti Titanium Bullet Super Tweeter 8 Ohm
in the Horn Loaded Bullet Tweeters product category.
