294-2800_ALT_0
PRV Audio DT175 1" Phenolic Horn Driver 8 Ohm 1-3/8"-18
Brand:| Model: DT175
Choose the PRV Audio DT175 1" screw-on compression driver as the perfect upgrade for the horn drivers in your speaker cabinet.
  • Phenolic diaphragm for smooth, natural sound
  • Kapton® former for longevity
  • High 108 dB sensitivity
  • Standard 1-3/8"-18 TPI threading
294-2800
Weight: 1.85 lbs.
IN STOCK
List Price$30.98
You Save22%
$23.99
Part # 294-2800
PRV Audio's DT175 1" phenolic compression driver offers smooth, natural, room-filling sound in a lightweight and affordable package that weighs-in at just under 1-1/2 pounds! The molded, standard 1-3/8"-18 TPI screw-on design allows the DT175 to be used as a replacement compression driver for many popular professional audio speaker cabinets, including stage, studio, and floor monitors.
A 1" CCAW (copper-clad aluminum) voice coil is wound on a Kapton® former to keep the moving mass at a minimum for the highest possible output. With a sensitivity of 108 dB, and a frequency response of 1,500 to 20,000 Hz, the DT175 can keep up with nearly any driver on the market.
Specifications: • Power handling: 75 watts RMS with recommended crossover of 2 kHz, 12 dB/octave slope • VCdia: 1" • Impedance: 8 ohms • Frequency response: 1,500-20,000 Hz • SPL: 108 dB 1W/1m • Dimensions: 3.31" diameter x 1.6" depth (2.62" with threads)  • Net weight: 1.68 lbs.
  • Mounting Type1-3/8"-18 TPI
  • Exit Diameter1"
  • Diaphragm MaterialPhenolic
  • Impedance8 ohms
  • Power Handling (RMS)75 Watts
  • BrandPRV Audio
  • ModelDT175
  • Part Number294-2800
  • UPC799928733885
  • Product CategoryHorn Drivers
    (1 Reviews)
  • Weight1.85 lbs.
View similar products to the PRV Audio DT175 1" Phenolic Horn Driver 8 Ohm 1-3/8"-18
in the Horn Drivers product category.
PRV Audio DT175 1" Phenolic Horn Driver 8 Ohm 1-3/8"-18 is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from good valuethis speaker was better all around than the original cabinet speaker.
Date published: 2013-10-23
can this replace selenium D220Ti in a econowave speaker (crossover 1600 hz}
Asked by: kannan.t
I would not recommend a crossover below 2kHz with this driver. The Econowave is designed around the D220Ti driver so using something different would not be a good idea.
Date published: 2013-09-09
I am looking for a substitute Compression Driver for the JBL 2414H-1. Crossover is 2khz. What would you recommend? These 300 series are not worth the $70.00 for the OEM Driver.
Asked by: Quantum_Guitar
This driver will work well as a replacement for the JBL.
Date published: 2014-01-17
Customer projects that include: PRV Audio DT175 1" Phenolic Horn Driver 8 Ohm 1-3/8"-18
