PRV Audio D4260Ph 2" Phenolic Midrange Horn Compression Driver 8 Ohm 4-Bolt
Brand:|Model: D4260Ph|Part # 294-2857
Choose PRV Audio's phenolic D4260Ph 2" exit horn driver for extreme high output applications where clean, controlled midrange and vocal content is required. A massive motor and 4" diameter voice coil on a Kapton former combine for 130 watts RMS power handling.
Part # 294-2857
  • PRV Audio's top-of-the-line midrange compression driver
  • High 109 dB SPL combined with high power handling
  • Pure titanium diaphragm for controlled frequency response from 500 to 6,000 Hz
  • Standard 2" output with 4-bolt mounting pattern
PRV Audio's D4260Ph phenolic 2" exit compression driver is designed for long throw and large format multi-way speakers, as well as line arrays. A huge ceramic magnet focuses energy in the motor's gap for complete control of the diaphragm at extremely high power levels, for accurate output from 500 to 5,500 Hz and a high sensitivity of 110 dB.
High power handling is accomplished through the use of a 4" diameter voice coil on a Kapton® former, for a power rating of 130 watts RMS (when used with a recommended 700 Hz, 12 dB/octave crossover), and makes the D4260Ph the compression driver of choice for vocals and midrange in high SPL mobile audio systems.
Specifications: • Power handling: 130 watts RMS with recommended crossover of 700 Hz, 12 dB/octave slope • VCdia: 4" • Impedance: 8 ohms • Frequency response: 500-6,000 Hz • SPL: 109 dB 2.83V/1m • Dimensions: 8.66" diameter x 2.68" depth • Net weight: 17.38 lbs. • Mounting: 4 x M6 bolt holes on a 4" diameter (hardware included) • Replacement diaphragm available (please see Related Items).
  • Mounting Type4-Bolt
  • Exit Diameter2"
  • Diaphragm MaterialPhenolic
  • Impedance8 ohms
  • Power Handling (RMS)130 Watts
  • BrandPRV Audio
  • ModelD4260Ph
  • Part Number294-2857
  • UPC799928733779
  • Product CategoryHorn Drivers
    (2 Reviews)
  • Weight18.1500 lbs.
View similar products to the PRV Audio D4260Ph 2" Phenolic Midrange Horn Compression Driver 8 Ohm 4-Bolt
in the Horn Drivers product category.
