PRV Audio D3220Ti-Nd 2" Titanium Neodymium Horn Compression Driver 8 Ohm 4-Bolt
Brand:|Model: D3220Ti-Nd|Part # 294-2851
Upgrade your speaker cabinets today using PRV Audio's D3220Ti-Nd 2" neodymium compression driver. High output and smooth frequency response allows you to use this horn driver in almost any high output audio application: pro, home, or car. Standard 4-bolt pattern and weighs less than 5 lbs.
List Price$285.78
You Save30%
$199.99
Part # 294-2851
  • Kapton® former and titanium diaphragm for neutral sound
  • Designed for high frequency use 1,600 to 19,000 Hz
  • High 108 dB sensitivity with lightweight neodymium motor
  • Four M6 bolt holes for secure horn coupling with included mounting bolts
  • Spring-loaded speaker terminals
PRV Audio's D3220Ti-Nd 2" pure titanium, neodymium compression driver offers a surprisingly smooth, neutral sound not normally found in titanium compression drivers at this price point, and weighs less than 5 pounds. In fact, the D3220Ti-Nd competes with drivers costing up to three times as much! A 2" exit and four bolt pattern makes this the perfect upgrade horn driver for many popular professional audio speaker cabinets.
High output mobile audio enthusiasts choose the PRV Audio D3220Ti-Nd for extreme SPL car audio competitions in South America, while DJs use it in high SPL speaker cabinets for entertaining crowds that number in the thousands. The neodymium motor helps to keep cabinets as light as possible, even when using this large format horn driver.
The pure titanium diaphragm is attached to a 3" diameter copper voice coil with Kapton® former for the lowest possible moving mass without sacrificing power handling. This allows for an amazing 108 dB of output with only 1 watt (2.83V) of input power, when measured at one meter, for use in even the loudest of environments! Mounting hardware is included
Specifications: • Power handling: 110 watts RMS with recommended crossover of 1,600 Hz, 12 dB/octave slope • VCdia: 3" • Impedance: 8 ohms • Frequency response: 1,600-19,000 Hz • SPL: 110 dB 1W/1m • Dimensions: 4.88" diameter x 2.2" depth • Net weight: 4.72 lbs. • Mounting: 4 x M6 bolt holes on a 4" diameter (hardware included) • Replacement diaphragm available (please see Related Items).
  • Mounting Type4-Bolt
  • Exit Diameter2"
  • Diaphragm MaterialTitanium
  • Impedance8 ohms
  • Power Handling (RMS)110 Watts
  • BrandPRV Audio
  • ModelD3220Ti-Nd
  • Part Number294-2851
  • UPC799928733816
  • Product CategoryHorn Drivers
  • Weight4.8500 lbs.
View similar products to the PRV Audio D3220Ti-Nd 2" Titanium Neodymium Horn Compression Driver 8 Ohm 4-Bolt
in the Horn Drivers product category.
