PRV Audio D290Py-B 1" Polyimide Horn Compression Driver 8 Ohm 2/3-Bolt
Brand:|Model: D290Py-B|Part # 294-2833
For crystal clear natural sound with accuracy, choose PRV Audio's D290Py-B 1" compression driver. Sonically similar to soft dome tweeters, the D290Py-B is at home in high-end monitors, high output home audio speakers, and any application that calls for a speaker with a smooth frequency response.
List Price$74.98
You Save20%
$59.99
PRV Audio WG16-25-B 1" 45 x 45 ABS Elliptical Tractrix Waveguide 2/3-Bolt
Qty: 1Part # 294-2890
List Price:$16.78
*Domestic US orders only
Part # 294-2833
  • Specially designed polyimide diaphragm for natural vocals
  • High energy motor for effortless 109 dB 2.83V/1m high output
  • Industry standard 2/3-bolt mounting with included hardware and screw-on adapter
PRV Audio's top-of-the-line D290Py-B polyimide 1" 2/3-bolt compression horn driver is designed to offer unsurpassed natural upper midrange and high frequency response, with accuracy not found in most manufacturer's stock PA speaker cabinets.
The specially designed polyimide diaphragm sounds very similar to the silk and textile dome tweeters used in high-end home audio speakers and studio monitors. PRV Audio combines this diaphragm with a high-energy motor for high output over the usable driver bandwidth for effortless, dynamic output.
High power handling is accomplished through the use of a Kapton® former and a 1-3/4" diameter voice coil, for a 90 watt RMS power rating when used with a 1,500 Hz 12 dB/octave high pass crossover, making the D290Py-B a drop-in upgrade replacement horn driver for nearly any speaker cabinet with an industry standard 2 or 3-bolt horn. Spring-loaded wire terminals facilitate quick connection. Includes screw-on adapter.
Also available in a 1-3/8"-18 TPI model.
Specifications: • Power handling: 110 watts RMS with recommended crossover of 1,600 Hz, 12 dB/octave slope • VCdia: 3" • Impedance: 8 ohms • Frequency response: 1,600-17,000 Hz • SPL: 109 dB 2.83V/1m • Dimensions: 4.72" diameter x 2.4" depth • Bolt thread and pattern: M6 x 2 (spaced at 3"), M6 x 3 (spaced at 2.4") • Net weight: 4.72 lbs. See the Related Items section for the replacement diaphragm.
  • Mounting Type2-Bolt/3-Bolt
  • Exit Diameter1"
  • Diaphragm MaterialKapton / Polyimide
  • Impedance8 ohms
  • Power Handling (RMS)90 Watts
  • BrandPRV Audio
  • ModelD290Py-B
  • Part Number294-2833
  • UPC799928733847
  • Product CategoryHorn Drivers
    (3 Reviews)
  • Weight4.9000 lbs.
View similar products to the PRV Audio D290Py-B 1" Polyimide Horn Compression Driver 8 Ohm 2/3-Bolt
in the Horn Drivers product category.
