PRV Audio D250Ph-S 1" Phenolic Horn Driver 8 Ohm 1-3/8"-18 TPI
Brand:|Model: D250Ph-S|Part # 294-2825
Choose PRV Audio's D250Ph-S when in need of a low-distortion midrange compression driver. Works great as the mid in a 3-way speaker cabinet or even as a PA driver for small venues and gymnasiums. Car audio SPL enthusiasts use the D250PH-S for vocal reinforcement.
OUT OF STOCK
Due In: 8/19/2016
List Price$42.88
You Save30%
$29.99
Part # 294-2825
  • Kapton® former for longevity and phenolic diaphragm for smooth sound
  • Designed for midrange use, 400-8,000 Hz
  • High 107 dB sensitivity
  • Standard 1-3/8"-18 TPI threading
  • Nickel-plated, spring-loaded speaker terminals
PRV Audio's D250Ph-S midrange phenolic compression driver is designed for use as a low-distortion mid in a three-way speaker cabinet, but can also serve as a PA announcement driver for gymnasiums and small venues due to its ability to capture the essence of voice and high 107 dB sensitivity.
High power handling and high sensitivity is achieved using a 2" diameter voice coil that is wound on a Kapton® former. A 1" exit and standard 1-3/8"-18 TPI threading allows the D250Ph-S to work as a replacement driver for many popular horns that play down to 500 Hz. The compact size and 3.11 pound weight allows for use where support brackets aren't available. Many high output, SPL car audio enthusiasts have gravitated to PRV Audio's D250Ph-S for it's high output and smooth vocal reinforcement.
Specifications: • Power handling: 75 watts RMS with recommended crossover of 500 Hz, 12 dB/octave slope • VCdia: 2" • Impedance: 8 ohms • Frequency response: 400-8,000 Hz • SPL: 107 dB 2.83V/1m • Dimensions: 4.41" diameter x 2.99" depth  • Net weight: 3.11 lbs. See the Related Items section for the replacement diaphragm.
  • Mounting Type1-3/8"-18 TPI
  • Exit Diameter1"
  • Diaphragm MaterialPhenolic
  • Impedance8 ohms
  • Power Handling (RMS)75 Watts
  • BrandPRV Audio
  • ModelD250Ph-S
  • Part Number294-2825
  • UPC799928733878
  • Product CategoryHorn Drivers
    (6 Reviews)
  • Weight2.95 lbs.
View similar products to the PRV Audio D250Ph-S 1" Phenolic Horn Driver 8 Ohm 1-3/8"-18 TPI
in the Horn Drivers product category.
