PRV Audio 8MB600 8" High Power PA Midbass Woofer 8 Ohm
Brand:|Model: 8MB600|Part # 294-2712
PRV Audio's 8MB600 features a high sensitivity design combined with a cast aluminum frame. Use the 8MB600 as a midbass and midrange in pro audio 3-way cabinets or as a woofer in small ported monitors. The most powerful 8" in the PRV Audio line is great for use in high SPL car audio systems.
  • Midbass or midrange for pro audio and high SPL car audio systems
  • High 94 dB sensitivity
  • Strong, yet lightweight cast aluminum frame
  • Designed for small ported cabinets
  • 300W RMS power handling
The 8MB600 8" PRV Audio midbass woofer is the most powerful 8" loudspeaker in the PRV Audio line. A truncated cast aluminum frame is used for close driver spacing for use as a midrange in line arrays, as a woofer in small ported cabinets, or as a midbass in professional three-way speaker cabinets.
Dynamic, punchy midbass is generated from the sensitive 300W RMS power handling motor design that features a 2" diameter voice coil. A durable woven spider is combined with a treated cloth surround and a thick, rigid paper cone for years of trouble-free operation, even in the most demanding high SPL car audio systems.
  • Nominal Diameter8"
  • Power Handling (RMS)300 Watts
  • Power Handling (max)600 Watts
  • Impedance8 ohms
  • Frequency Response76 to 6,000 Hz
  • Sensitivity95 dB 2.83V/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)76.04 Hz
  • DC Resistance (Re)5 ohms
  • Voice Coil Inductance (Le)1.17 mH
  • Mechanical Q (Qms)7.04
  • Electromagnetic Q (Qes)0.58
  • Total Q (Qts)0.53
  • Compliance Equivalent Volume (Vas)0.36 ft.³
  • BL Product (BL)10.66 Tm
  • Diaphragm Mass Inc. Airload (Mms)27.78g
  • Maximum Linear Excursion (Xmax)6 mm
  • Surface Area of Cone (Sd)213.8 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.27" across the flats, 9.41"
  • Baffle Cutout Diameter7.28"
  • Depth3.11"
  • # Mounting Holes4
  • Sealed Volume0.22 ft.³
  • Sealed F3119 Hz
  • Vented Volume0.57 ft.³
  • Vented F357 Hz
  • BrandPRV Audio
  • Model8MB600
  • Part Number294-2712
  • UPC799928733694
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
  • Weight7.65 lbs.
View similar products to the PRV Audio 8MB600 8" High Power PA Midbass Woofer 8 Ohm
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
