PRV Audio 8MB500-NDY Neodymium 8" Midbass/Midrange Woofer 8 Ohm
Brand:|Model: 8MB500-NDY|Part # 294-2711
A lightweight neodymium motor, extreme power handling, and punchy midbass are the hallmarks of PRV Audio's 8MB500-NDY. A great choice for professional 3-way cabinets, floor and studio monitors, even for use in high SPL mobile audio systems.
List Price$74.98
You Save20%
$59.99
Part # 294-2711
  • Lightweight neodymium version of the popular 8MB450
  • Smooth midrange combined with strong midbass punch
  • Strong, yet lightweight stamped steel frame
  • Designed for small sealed and ported cabinets
  • 250W RMS power handling
PRV Audio's 8MB500-NDY neodymium 8" midbass woofer is a lighter version of the popular 8MB450 and offers the same high output punch, a smooth midrange, and response up to 4,000 Hz. A lower Qts motor design offers more driver control, and a lower free-air response allows it to reach a little bit deeper. The 8MB500 is designed for use as a midbass or midrange driver in 3-way speakers. Alternatively, you can use this speaker in small sealed and ported cabinets as a woofer in floor and studio monitors.
A thick, light, and rigid paper cone is mated to a 2" voice coil for great sensitivity and high power handling. A durable spider suspension, woven cloth surround, and stamped steel frame are combined for extreme durability. High output SPL car audio enthusiasts gravitate towards this driver for use in their systems when looking for a lightweight midrange or midbass that can sustain long hours of extreme operation.
  • Nominal Diameter8"
  • Power Handling (RMS)250 Watts
  • Power Handling (max)500 Watts
  • Impedance8 ohms
  • Frequency Response62 to 4,000 Hz
  • Sensitivity95 dB 2.83V/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)67.4 Hz
  • DC Resistance (Re)6 ohms
  • Voice Coil Inductance (Le)0.95 mH
  • Mechanical Q (Qms)9.19
  • Electromagnetic Q (Qes)0.60
  • Total Q (Qts)0.57
  • Compliance Equivalent Volume (Vas)0.6 ft.³
  • BL Product (BL)10.57 Tm
  • Diaphragm Mass Inc. Airload (Mms)26.53g
  • Maximum Linear Excursion (Xmax)3.5 mm
  • Surface Area of Cone (Sd)241 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialNeodymium
  • Overall Outside Diameter8.23"
  • Baffle Cutout Diameter7.05"
  • Depth3.54"
  • Sealed Volume0.43 ft.³
  • Sealed F396 Hz
  • Vented Volume1.04 ft.³
  • Vented F346 Hz
  • BrandPRV Audio
  • Model8MB500-NDY
  • Part Number294-2711
  • UPC799928733700
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (6 Reviews)
  • Weight3 lbs.
View similar products to the PRV Audio 8MB500-NDY Neodymium 8" Midbass/Midrange Woofer 8 Ohm
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
