294-2702_ALT_0
294-2702_ALT_1
PRV Audio 6MB300SEAL 6-1/2" Sealed Back Midbass Midrange Woofer 8 Ohm
Brand:| Model: 6MB300SEAL
PRV Audio designed the 6MB300SEAL sealed-back 6-1/2" midbass/midrange woofer offers the same punch as the 6MB200, without the shared enclosure air modulation issues associated with open-back midrange/midbass speakers when installed in cabinets with larger woofers.
  • Great choice for pro audio and car audio systems
  • Strong midbass punch
  • 150W RMS power handling
  • Sealed-back basket eliminates for separate enclosure in 3-way speakers
294-2702
Weight: 4.8 lbs.
IN STOCK
List Price$58.48
You Save33%
$38.99
Part # 294-2702
A sealed-back basket design on PRV Audio's 6MB300SEAL 6-1/2" midbass/midrange woofer protects it from the air swept by larger drivers in a shared cabinet. This results in decreased driver distortion, increased durability, and increased midbass punch from 250 to 500 Hz and power handling over the open-back 6MB200.
A thick, yet light and rigid paper cone, 1.5" voice coil, durable spider suspension, and a woven surround supported by a sturdy steel basket. All of this ensures its ability to withstand long hours of operation making this driver a popular speaker choice amongst high output car audio enthusiasts, especially when you consider the extra moisture protection offered by the sealed-back design.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)150 Watts
  • Power Handling (max)300 Watts
  • Impedance8 ohms
  • Frequency Response310 to 6,000 Hz
  • Sensitivity93 dB 2.83V/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)369.4 Hz
  • DC Resistance (Re)5.7 ohms
  • Mechanical Q (Qms)8.77
  • Electromagnetic Q (Qes)2.78
  • Total Q (Qts)2.11
  • Compliance Equivalent Volume (Vas)0.007 ft.³
  • BL Product (BL)11.11 Tm
  • Diaphragm Mass Inc. Airload (Mms)25.92g
  • Maximum Linear Excursion (Xmax)5 mm
  • Surface Area of Cone (Sd)136.85 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.57"
  • Baffle Cutout Diameter5.82"
  • Depth3.26"
  • # Mounting Holes4
  • BrandPRV Audio
  • Model6MB300SEAL
  • Part Number294-2702
  • UPC799928733731
  • Product CategoryWoofers, Subwoofers & Midrange Speakers
    (3 Reviews)
  • Weight4.8 lbs.
View similar products to the PRV Audio 6MB300SEAL 6-1/2" Sealed Back Midbass Midrange Woofer 8 Ohm
in the Woofers, Subwoofers & Midrange Speakers product category.
PRV Audio 6MB300SEAL 6-1/2" Sealed Back Midbass Midrange Woofer 8 Ohm is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Excellent SoundGreat Price! Fast Shipping! & Great Sound! It's sounds like if I'm in a club! The volume in my car radio goes up to 100 and on 5 it's sounds beautiful...!!! I think I'm going to get me two 10" for my room...lol that's how good the sounds is on these speaker...!! I'm loving it :)))
Date published: 2014-05-15
Rated 5 out of 5 by from Accurate specs; very loud!After testing these midranges, I found that the 1-watt SPL, frequency response, and the RMS wattage rating are all accurate. The sound quality is excellent, even with the most demanding computer-generated music, which is why I'm giving this midrange five stars.The only problem I had was that part of the basket (as seen in the attached photo) was bent when I took it out of the box. I didn't feel like exchanging the driver, so I just used a hammer to straighten it out, which worked out very well.So what is this driver capable of? If you use a first-order high-pass filter at roughly 1000 hertz, then you'll be able to produce sound pressure levels high enough for a high school dance in a full-sized gymnasium, but nothing larger than that.
Date published: 2014-04-11
Rated 5 out of 5 by from Decent sealed midI used these to replace some Dayton RS52AN-8's that met an unfortunate demise as I was putting together my new active crossover setup. Couldn't be happier that I made that mistake now that they're installed. The midrange is much fuller with a good spl match to my other components and I have more flexibility with the crossover points. I'm still waiting on a couple more items and will be measuring response with the new Dayton EMM-6 Mic I picked up recently to EQ the speakers and room with my miniDSP2x8 xo.There weren't many reviews for these speakers when I purchased them but the specs matched my needs quite well and using sealed back units again made the process of replacement easy - not needing to seal off another part of the enclosure for a mid driver of this size. Nice construction and the workmanship seems good.I don't know about the rest of PRV's line but if the specs match your needs I wouldn't hesitate on recommending this one.
Date published: 2013-05-28
Is there an impedence plot available for this driver? Wanting to work on the crossover.  Thanks!!
Asked by: GWally
PRV does not supply one, but if you contact our tech support we can pull a unit from stock and email a copy of the impedance graph to you. Please contact our tech support at tech@parts-express.com or 800-338-0531 x1.
Date published: 2014-10-15
What size of hole do I need to cut to fit it I'm properly
Asked by: Timbo111
Thank you for your interest in PRV Audio products. I have verified that the cutout of 5.82" listed on the specifications sheet (listed under Manuals/Resources) and on the Mounting Information (listed under Product Details) is correct if front mounted onto a baffle.Some customers choose to rear mount this speaker. If that is what you would like to do, please cut a 5-15/16" hole (5.9375").
Answered by: PRVAudioBrazil
Date published: 2014-10-07
Can you get these without the logo on the cone?
Asked by: GWally
These are not available without a logo.
Date published: 2014-09-19
is it one in a box or a pair
Asked by: rude
These are sold individually.
Date published: 2014-09-17
I am building a three way system using the above driver and a Dayton Audio PA310-8 12" Pro Woofer. I am looking for a recommended cross frequency, this mid can reach low. Can frequencies overlap, what would the effect be?
Asked by: Tomane
While the Fs for this driver is around 300 Hz, I would not recommend crossing it any lower than about 500 Hz due to a high Q bump in the low end response which can be seen on the PRV spec sheet. It is common for frequencies to overlap from one driver to another.
Date published: 2014-09-11
I am rebuilding some infinity 3000's, would this make a good mid for home use? I like how the driver is sealed, I won't have to build a mid enclosure in the existing box. What are some considerations when using pro speakers vs. hf? Thanks!
Asked by: Tomane
There aren't any specific considerations to pay attention to when using pro drivers over home drivers. These will work the same way, only provide more output capability. A sealed back midrange like this will have a pretty bit bottom end peak that will need to be taken care of in the crossover, but crossing it a little higher (around say 6-700 Hz) will help with this a lot.
Customer projects that include: PRV Audio 6MB300SEAL 6-1/2" Sealed Back Midbass Midrange Woofer 8 Ohm
