PRV Audio 6MB200-4 6-1/2" Midbass Woofer 4 Ohm
Brand:|Model: 6MB200-4 |Part # 294-2703
PRV Audio's 6MB200-4 6" midbass woofer offers outstanding durability and a smooth punch for small enclosures. The 6MB200-4 is perfect for home installs such as bookshelves, surround sound, and home studio monitors.
List Price$37.48
You Save20%
$29.99
Part # 294-2703
  • Great choice for pro audio and car audio systems
  • Smooth midrange combined with strong midbass punch
  • Strong, yet lightweight stamped steel frame
  • 100W RMS power handling
  • 4 ohm impedance for car audio use
Offering a smooth mid-range and midbass response up to 4.5 kHz, the 6MB200-4 is great option for midrange driver replacement for 3-way cabinets. Attached to a sturdy reinforced steel frame, the magnet and motor assembly completes the solid support structure for long lasting play in most environments. Weighing only 3.3 lbs, this woofer is also great for used in car doors.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)100 Watts
  • Power Handling (max)200 Watts
  • Impedance4 ohms
  • Frequency Response125 to 4,500 Hz
  • Sensitivity93 dB 2.83V/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)114.5 Hz
  • DC Resistance (Re)3.7 ohms
  • Voice Coil Inductance (Le)0.43 mH
  • Mechanical Q (Qms)24.3
  • Electromagnetic Q (Qes)0.86
  • Total Q (Qts)0.83
  • Compliance Equivalent Volume (Vas)0.18 ft.³
  • Mechanical Compliance of Suspension (Cms)0.155 mm/N
  • BL Product (BL)6.18 Tm
  • Diaphragm Mass Inc. Airload (Mms)12.41g
  • Maximum Linear Excursion (Xmax)3.5 mm
  • Surface Area of Cone (Sd)136.85 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.53"
  • Baffle Cutout Diameter5.63"
  • Depth2.60"
  • # Mounting Holes4
  • Sealed Volume0.58 ft.³
  • Sealed F3115 Hz
  • Vented Volume0.81 ft.³
  • Vented F353 Hz
  • BrandPRV Audio
  • Model6MB200-4
  • Part Number294-2703
  • UPC799928734325
    (6 Reviews)
  • Weight3.6200 lbs.
