294-2862_ALT_1
294-2862_ALT_2
PRV Audio 1DF750/1000 Subwoofer Crossover 750 Hz
Brand:| Model: 1DF750/1000
Get your professional audio subwoofer speaker cabinet up and running like new with the PRV Audio 1DF750/1000 subwoofer crossover. A speakON-compatible input and pass-through output makes amplifier connection simple, quick, and secure.
  • Perfect replacement crossover for subwoofer cabinets
  • speakON-compatible input/output connectors
  • Parallel output connections for daisy-chaining speakers
294-2862
Weight: 2.95 lbs.
IN STOCK
List Price$101.98
You Save33%
$67.99
Part # 294-2862
The PRV Audio 1DF750/1000 subwoofer crossover was originally designed to be used as a replacement crossover for passive (unpowered) subwoofer cabinets. A 750 Hz crossover point, 12 dB/octave filter slope was chosen to integrate with nearly any two-way speaker system.
For safe, secure, and quick amplifier connection, PRV Audio built the 1DF750/1000 crossover with a 4-pole speakON-compatible input jack and output pass-through (for daisy-chaining multiple speakers together). High quality components are used throughout for longevity and great sound.
Note: Each connector is wired 1+ to 2+ and 1- to 2-. Please consult your amplifier manual to see if this affects amplifier operation prior to connecting 4-pole speakON-compatible speaker cables. 2-pole speakON-compatible speaker cables are not affected.
Specifications: • Power handling: 1,000W RMS • Crossover point: 750 Hz (when connected to 8 ohm drivers), 12 dB/octave • Input/output connections: 4-pole speakON-compatible (see note above) • Overall dimensions: 5.2" W x 7.1" H x 4" D, Cutout: 3.9" W x 5.9" H.
  • Crossover TypeSubwoofer
  • ConfigurationConnector Dish
  • BrandPRV Audio
  • Model1DF750/1000
  • Part Number294-2862
  • UPC799928734011
  • Product CategoryAssembled Passive Crossovers
    (1 Reviews)
  • Weight2.95 lbs.
View similar products to the PRV Audio 1DF750/1000 Subwoofer Crossover 750 Hz
in the Assembled Passive Crossovers product category.
PRV Audio 1DF750/1000 Subwoofer Crossover 750 Hz is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from wonderful product butits a wonderful product buuut i just wish it had markings for in /out on the speakon connectors
Date published: 2013-07-27
what is the peak power that this crossover can handle?
Asked by: boss2014
Peak power is not listed although it is common to double RMS for this number. Since you never really want to exceed an RMS rating, the peak numbers are generally irrelevant.
Date published: 2014-04-09
Customer projects that include: PRV Audio 1DF750/1000 Subwoofer Crossover 750 Hz
