294-2862_ALT_1
294-2862_ALT_2
PRV Audio 1DF750/1000 Subwoofer Crossover 150 Hz
Brand:|Model: 1DF750/1000|Part # 294-2862
Get your professional audio subwoofer speaker cabinet up and running like new with the PRV Audio 1DF750/1000 subwoofer crossover. A speakON-compatible input and pass-through output makes amplifier connection simple, quick, and secure.
  • Perfect replacement crossover for subwoofer cabinets
  • speakON-compatible input/output connectors
  • Parallel output connections for daisy-chaining speakers
The PRV Audio 1DF750/1000 subwoofer crossover was originally designed to be used as a replacement crossover for passive (unpowered) subwoofer cabinets. A 150 Hz crossover point, 12 dB/octave filter slope was chosen to integrate with nearly any two-way speaker system.
For safe, secure, and quick amplifier connection, PRV Audio built the 1DF750/1000 crossover with a 4-pole speakON-compatible input jack and output pass-through (for daisy-chaining multiple speakers together). High quality components are used throughout for longevity and great sound.
Note: Each connector is wired 1+ to 2+ and 1- to 2-. Please consult your amplifier manual to see if this affects amplifier operation prior to connecting 4-pole speakON-compatible speaker cables. 2-pole speakON-compatible speaker cables are not affected.
Specifications: • Power handling: 1,000W RMS • Crossover point: 150 Hz (when connected to 8 ohm drivers), 12 dB/octave • Input/output connections: 4-pole speakON-compatible (see note above) • Overall dimensions: 5.2" W x 7.1" H x 4" D, Cutout: 3.9" W x 5.9" H.
  • Crossover TypeSubwoofer
  • ConfigurationIncludes Connector Dish
  • BrandPRV Audio
  • Model1DF750/1000
  • Part Number294-2862
  • UPC799928734011
  • Product CategoryAssembled Passive Crossovers
    (3 Reviews)
  • Weight2.95 lbs.
View similar products to the PRV Audio 1DF750/1000 Subwoofer Crossover 150 Hz
in the Assembled Passive Crossovers product category.
