PRV Audio 18SW3000 18" High Power Pro Audio Subwoofer 8 Ohm
Brand:|Model: 18SW3000|Part # 294-2755
PRV Audio builds the 18SW3000 to be a cost-no-object, no-holds-barred 18" subwoofer that competes with other subwoofers nearly twice its price! FACT cooling enables higher power handling without the power compression experienced with lesser subwoofers.
List Price$412.48
You Save20%
$329.99
Part # 294-2755
  • Better than other subwoofers that cost twice as much!
  • High 1,500 watt RMS power handling and 8 mm of Xmax
  • Cast aluminum, 8-spoke frame and spring-loaded terminals
  • Dual spider suspension and cotton M-Roll surround for driver linearity
  • 5" voice coil motor with extreme ventilation for minimum power compression
The 18SW3000 is the most powerful loudspeaker in the SW series woofer from PRV Audio and finds itself at home in either bandpass or bass reflex systems. Dual spiders and an M-Roll surround combine to offer precise cone movement along its impressive 16 mm of stroke.
A class-leading 5" diameter voice coil is mounted onto a fiberglass former to provide the foundation that allows for 1,500 watts of RMS power handling (3,000 watts program power) and is kept cool through the unique, built-in FACT (Forced Air Cooling Technology) system that draws air from above and below the gap for a complete cooling cycle that works with the subwoofer's natural movement.
Insane 1,500 watt RMS power handling, high 96 dB sensitivity, and reasonably small enclosure requirements make PRV Audio's 18SW3000 a true, high-end powerhouse subwoofer. Perfect for shaking a venue, high SPL car audio, or for the ultimate home theater subwoofer!
  • Nominal Diameter18"
  • Power Handling (RMS)1,500 Watts
  • Power Handling (max)3,000 Watts
  • Impedance8 ohms
  • Frequency Response47 to 1,800 Hz
  • Sensitivity96 dB 2.83V/1m
  • Voice Coil Diameter5"
  • Resonant Frequency (Fs)46.8 Hz
  • DC Resistance (Re)5.2 ohms
  • Voice Coil Inductance (Le)1.85 mH
  • Mechanical Q (Qms)21.10
  • Electromagnetic Q (Qes)0.38
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)4.03 ft.³
  • Mechanical Compliance of Suspension (Cms)0.049 mm/N
  • BL Product (BL)30.6 Tm
  • Diaphragm Mass Inc. Airload (Mms)234.7g
  • Maximum Linear Excursion (Xmax)8 mm
  • Surface Area of Cone (Sd)1,288 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.58"
  • Baffle Cutout Diameter16.30"
  • Depth8.15"
  • # Mounting Holes8
  • Vented Volume2.80 ft.³
  • Vented F354 Hz
  • BrandPRV Audio
  • Model18SW3000
  • Part Number294-2755
  • UPC799928733533
  • Weight47.15 lbs.
View similar products to the PRV Audio 18SW3000 18" High Power Pro Audio Subwoofer 8 Ohm
