PRV Audio 18SW2500 18" High Power Pro Audio Subwoofer 8 Ohm
Brand:|Model: 18SW2500|Part # 294-2754
PRV Audio builds the 18SW2500 to be a cost-no-object, no-holds-barred 18" subwoofer that competes with other subwoofers nearly twice its price!
  • Better than other subwoofers that cost twice as much!
  • High 1,250 watt RMS power handling and 8 mm of Xmax
  • Cast aluminum, 8-spoke frame and spring-loaded terminals
  • Dual spider suspension and cotton M-Roll surround for driver linearity
  • 5" voice coil motor with extreme ventilation for minimum power compression
The 18SW2500 is the second most powerful loudspeaker in the SW series woofer from PRV Audio and finds itself at home in either bandpass or bass reflex systems. A specially designed force air ventilation system (ported polepiece and voice coil cooling ports) and eight-spoke cast aluminum frame ensures proper cooling of the massive 5" voice coil, for intense playback in dance clubs with minimum power compression. Dual spiders and an M-Roll surround combine to offer precise cone movement along its impressive 18 mm of total travel.
Insane 1,250 watt RMS power handling, high 99 dB sensitivity, and reasonably small enclosure requirements make PRV Audio's 18SW2500 a true, high-end powerhouse subwoofer. Perfect for shaking a venue, high SPL car audio, or for the ultimate home theater subwoofer!
  • Nominal Diameter18"
  • Power Handling (RMS)1,250 Watts
  • Power Handling (max)2500 Watts
  • Impedance8 ohms
  • Frequency Response25 to 1,500 Hz
  • Sensitivity99 dB 2.83V/1m
  • Voice Coil Diameter5"
  • Resonant Frequency (Fs)41.72 Hz
  • DC Resistance (Re)5.68 ohms
  • Mechanical Q (Qms)12.19
  • Electromagnetic Q (Qes)0.51
  • Total Q (Qts)0.49
  • Compliance Equivalent Volume (Vas)4.66 ft.³
  • BL Product (BL)24.44 Tm
  • Diaphragm Mass Inc. Airload (Mms)229.1g
  • Maximum Linear Excursion (Xmax)9 mm
  • Surface Area of Cone (Sd)1590 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.2"
  • Baffle Cutout Diameter16.5"
  • Depth8.3"
  • # Mounting Holes8
  • Sealed Volume2.64 ft.³
  • Sealed F367 Hz
  • Vented Volume7.3 ft.³
  • Vented F333 Hz
  • BrandPRV Audio
  • Model18SW2500
  • Part Number294-2754
  • UPC799928733540
    (1 Reviews)
  • Weight43 lbs.
View similar products to the PRV Audio 18SW2500 18" High Power Pro Audio Subwoofer 8 Ohm
