PRV Audio 18SW2200-2+2 18" High Power Pro Audio DVC Subwoofer 2+2 Ohms
Brand:|Model: 18SW2200-2+2 |Part # 294-2757
PRV Audio's 18" 18SW2200-2+2 subwoofer performs at many levels above its price point. 9 mm of Xmax, a 4" diameter voice coil, dual spider, and cotton M-Roll suspension all combine to form a subwoofer that remains linear at power levels up to 1,100 watts RMS! The class leading 105 dB sensitivity (2.83V/1m) offers the performance of up to four 18" subwoofers in a single driver package.
  • One of the highest sensitivity 18" subwoofers on the market at 97 dB, 2.83V/1m
  • Built to be used with high current amplifiers
  • Dual spiders and a polycotton M-roll surround for linear excursion
  • Two 2 ohm voice coils for use with 4 ohm amplifiers, dual 2 ohm stable amplifiers, and monster 1 ohm mono amplifiers
The 18SW2200-2+2 18" subwoofer is one of the best selling professional audio loudspeakers in the PRV Audio subwoofer series. Its low frequency response and accuracy surprises listeners, not expecting this much performance from a subwoofer at this price point.
PRV Audio built the 18" 18SW2200-2+2 to play louder (97 dB, 2.83V/1m) than nearly every subwoofer on the market, by using a thoroughly vented, well executed motor. A 4" inside-outside dual voice coil is employed to minimize output-robbing power compression, while also increasing driver longevity and power handling. The use of a dual spider suspension, mated to a cotton M-Roll surround and ribbed cone (all attached with a special resin), allows for extreme linearity during intense use.
A reinforced cast aluminum frame increases rigidity and resists frame flex. Spring-loaded speaker terminals allow for easy speaker wire connection. This professional audio subwoofer is at home in bandpass or ported (bass reflex) speaker cabinets and has been used in live sound reinforcement, high SPL mobile audio systems, and as high output home theater systems.
Note: Specifications are listed with voice coils wired in parallel.
  • Nominal Diameter18"
  • Power Handling (RMS)1,100 Watts
  • Power Handling (max)2,200 Watts
  • Impedance2+2 ohms
  • Frequency Response35 to 1,200 Hz
  • Sensitivity97 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)33.16 Hz
  • DC Resistance (Re)5.4 ohms
  • Voice Coil Inductance (Le)1.78 mH
  • Mechanical Q (Qms)16.82
  • Electromagnetic Q (Qes)0.39
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)9.84 ft.³
  • Mechanical Compliance of Suspension (Cms)0.120 mm/N
  • BL Product (BL)23.61 Tm
  • Diaphragm Mass Inc. Airload (Mms)191g
  • Maximum Linear Excursion (Xmax)9 mm
  • Surface Area of Cone (Sd)1,288 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.11"
  • Baffle Cutout Diameter16.65"
  • Depth7.48"
  • # Mounting Holes8
  • Sealed Volume2.89 ft.³
  • Sealed F370 Hz
  • Vented Volume6.84 ft.³
  • Vented F339 Hz
  • BrandPRV Audio
  • Model18SW2200-2+2
  • Part Number294-2757
  • UPC799928734387
  • Weight30.8000 lbs.
View similar products to the PRV Audio 18SW2200-2+2 18" High Power Pro Audio DVC Subwoofer 2+2 Ohms
