PRV Audio 18SW2200 18" High Power Pro Audio Subwoofer 8 Ohm
Brand:|Model: 18SW2200|Part # 294-2752
PRV Audio's 18" 18SW2200 subwoofer performs at many levels above its price point. 9 mm of Xmax, a 4" diameter voice coil, dual spider, and cotton M-Roll suspension all combine to form a subwoofer that remains linear at power levels up to 1,100 watts RMS!
Comparable Items In Stock:
Part # 294-2752
  • Amazing performance-to-price ratio and PRV Audio's most popular subwoofer
  • High 1,100 watt RMS power handling and 9 mm of Xmax
  • Cast aluminum frame and spring-loaded terminals
  • Dual spider suspension and cotton M-Roll surround for driver linearity
  • 4" inside-outside voice coil motor with extreme ventilation for minimum power compression
The 18SW2200 18" subwoofer is one of the best selling professional audio loudspeakers in the PRV Audio subwoofer series. Its low frequency response and accuracy surprises listeners, not expecting this much performance from a subwoofer at this price point.
PRV Audio built the 18" 18SW2200 to play louder, and lower, by using a thoroughly vented, well executed motor. A 4" inside-outside voice coil is employed to minimize output-robbing power compression, while also increasing driver longevity and power handling. The use of a dual spider suspension, mated to a cotton M-Roll surround and ribbed cone (all attached with a special resin), allows for extreme linearity during intense use.
A reinforced cast aluminum frame increases rigidity and resists frame flex. Spring-loaded speaker terminals allow for easy speaker wire connection. This professional audio subwoofer is at home in bandpass or ported (bass reflex) speaker cabinets and has been used in live sound reinforcement, high SPL mobile audio systems, and as high output home theater systems.
  • Nominal Diameter18"
  • Power Handling (RMS)1,100 Watts
  • Power Handling (max)2,000 Watts
  • Impedance8 ohms
  • Frequency Response35 to 2,000 Hz
  • Sensitivity97 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)33.16 Hz
  • DC Resistance (Re)5.4 ohms
  • Voice Coil Inductance (Le)1.78 mH
  • Mechanical Q (Qms)16.82
  • Electromagnetic Q (Qes)0.39
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)9.84 ft.³
  • Mechanical Compliance of Suspension (Cms)9.84 mm/N
  • BL Product (BL)23.61 Tm
  • Diaphragm Mass Inc. Airload (Mms)191g
  • Maximum Linear Excursion (Xmax)9 mm
  • Surface Area of Cone (Sd)1,288 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.11"
  • Baffle Cutout Diameter16.65"
  • Depth7.48"
  • # Mounting Holes8
  • Sealed Volume2.89 ft.³
  • Sealed F370 Hz
  • Vented Volume6.84 ft.³
  • Vented F339 Hz
  • BrandPRV Audio
  • Model18SW2200
  • Part Number294-2752
  • UPC799928733564
    (3 Reviews)
  • Weight31.4 lbs.
View similar products to the PRV Audio 18SW2200 18" High Power Pro Audio Subwoofer 8 Ohm
