PRV Audio 18SW2000 18" High Power Pro Audio Subwoofer 8 Ohm
Brand:|Model: 18SW2000|Part # 294-2751
The 18" 18SW2000 was the first high-powered professional subwoofer ever built by PRV Audio, and is still their most popular subwoofer. A 4" voice coil, with nearly 8 mm of Xmax, is mated to a dual spider and M-Roll surround for extreme linearity at low frequencies.
Comparable Items In Stock:
Part # 294-2751
  • Amazing performance-to-price ratio and PRV Audio's most popular subwoofer
  • High 1,000 watt RMS power handling
  • Cast aluminum frame and spring-loaded terminals
  • Dual spider suspension and cotton M-Roll surround for driver linearity
  • 4" inside-outside voice coil motor with extreme ventilation for minimum power compression
The 18SW2000 18" subwoofer was the first high-power driver designed and built by PRV Audio, and continues to be their best selling, most popular subwoofer today. One look at this driver and you'll see why!
PRV Audio designed the 18SW2000 to play louder, and lower, than most every other speaker manufacturer's subwoofer in its price range. A thoroughly vented, well executed motor with an inside-outside 4" voice coil is utilized to minimize output-robbing power compression, while also increasing driver longevity and power handling. The use of a dual spider suspension, mated to a cotton M-Roll surround and attached with a special resin, allows for extreme linearity during intense use.
A reinforced cast aluminum frame increases rigidity and resists frame flex. Spring-loaded speaker terminals allow for easy speaker wire connection. This popular professional audio subwoofer is at home in bandpass or ported (bass reflex) speaker cabinets and has been used in live sound reinforcement, high SPL mobile audio systems, and as high output home theater systems.
  • Nominal Diameter18"
  • Power Handling (max)2,000 Watts
  • Impedance8 ohms
  • Frequency Response50 to 2,500 Hz
  • Sensitivity97 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)38.36 Hz
  • DC Resistance (Re)5 ohms
  • Mechanical Q (Qms)11.36
  • Electromagnetic Q (Qes)0.37
  • Total Q (Qts)0.36
  • Compliance Equivalent Volume (Vas)6.11 ft.³
  • BL Product (BL)26.39 Tm
  • Diaphragm Mass Inc. Airload (Mms)181.6g
  • Maximum Linear Excursion (Xmax)7.8 mm
  • Surface Area of Cone (Sd)1,250 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.2"
  • Baffle Cutout Diameter16.4"
  • Depth8.3"
  • # Mounting Holes8
  • Sealed Volume1.47 ft.³
  • Sealed F385 Hz
  • Vented Volume3.35 ft.³
  • Vented F350 Hz
  • BrandPRV Audio
  • Model18SW2000
  • Part Number294-2751
  • UPC799928733571
    (2 Reviews)
  • Weight31.1 lbs.
View similar products to the PRV Audio 18SW2000 18" High Power Pro Audio Subwoofer 8 Ohm
