PRV Audio 18SW1800 18" High Power PA Subwoofer 8 Ohm
Brand:|Model: 18SW1800|Part # 294-2750
Choose the PRV Audio 18SW1800 18" subwoofer for replacing old, worn-out, or blown drivers in your PA speaker cabinet. The 18SW1800 works equally well in ported or horn-loaded cabinets and offers features not normally found in woofers at this price point.
  • Perfect replacement subwoofer for vented and horn-loaded cabinets
  • 4" voice coil for 900W RMS power handling
  • 5 mm of Xmax and a low Fs for playing below 40 Hz with authority
  • Paper cone captures that "classic tone" of high-end speakers
  • High 97 dB sensitivity
The PRV Audio 18SW1800 18" professional audio subwoofer is designed to be a perfect drop-in replacement for many popular PA subwoofer speaker cabinets and works equally well in ported or horn-loaded cabinets. In the motor, you'll find features not normally associated with other drivers at this price point: a 4" diameter voice coil with a Kapton® former and 5 mm of Xmax, relatively high sensitivity, and a fairly low free-air resonance that allows this driver to play down below 40 Hertz. A specially designed resin was been applied to the woven spider for increased longevity, and the cloth accordion surround ensures smooth, accurate sound.
A non-pressed pulp cone offers a natural classic tone found in most high-end PA speaker cabinets, making the 18W1800 driver an ideal replacement woofer or subwoofer in both ported and sealed speakers. A special compound is incorporated into the the woven cotton surround to resist against wear for years of use. Spring-loaded speaker terminals make quick connection a breeze.
  • Nominal Diameter18"
  • Power Handling (RMS)900 Watts
  • Power Handling (max)1800 Watts
  • Impedance8 ohms
  • Frequency Response30 to 2,500 Hz
  • Sensitivity96 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)30.28 Hz
  • DC Resistance (Re)4.9 ohms
  • Mechanical Q (Qms)11.61
  • Electromagnetic Q (Qes)0.41
  • Total Q (Qts)0.39
  • Compliance Equivalent Volume (Vas)9.1 ft.³
  • BL Product (BL)22.63 Tm
  • Diaphragm Mass Inc. Airload (Mms)223.1g
  • Maximum Linear Excursion (Xmax)5 mm
  • Surface Area of Cone (Sd)1229 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.2"
  • Baffle Cutout Diameter16.68"
  • Depth6.76"
  • # Mounting Holes8
  • Sealed Volume2.79 ft.³
  • Sealed F361 Hz
  • Vented Volume6.98 ft.³
  • Vented F334 Hz
  • BrandPRV Audio
  • Model18SW1800
  • Part Number294-2750
  • UPC799928733588
    (1 Reviews)
  • Weight29.1 lbs.
View similar products to the PRV Audio 18SW1800 18" High Power PA Subwoofer 8 Ohm
