PRV Audio 18FH2400 18" Folded Horn Pro Audio Subwoofer 8 Ohm
Brand:|Model: 18SFH2400|Part # 294-2753
PRV Audio's 18" 18FH2400 subwoofer is designed to be a drop-in replacement speaker for folded horn subwoofer cabinets. 7 mm of Xmax also makes this driver perfect for vented subwoofer cabinets.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$335.78
You Save30%
$234.99
Part # 294-2753
  • The perfect folded horn subwoofer
  • High 1,200 watt RMS power handling and 7 mm of Xmax
  • Cast aluminum, 4-spoke frame and spring-loaded terminals
  • Dual spider suspension and cotton M-Roll surround for driver linearity
  • 4" voice coil motor with extreme ventilation for minimum power compression
The 18FH2400 18" subwoofer, from PRV Audio, is purpose-built for use in folded horn subwoofer enclosures, but also features 7 mm of Xmax for use in vented bass reflex cabinets. A unique four-spoke, cast aluminum frame is used for rigidity and minimum backwave reflection. Dual spiders are combined with an M-Roll surround to keep the cone travel uniform throughout the driver's stroke.
A high 1,200 watt power handling is achieved with the 4" voice coil that is cooled by the ported pole piece, and cone geometry is maintained by a layer of non-pressed paper on the underside. A high BL magnet assembly saturates the motor structure for a Qts of 0.35, making the 18FH2400 the ideal candidate for your horn-loaded subwoofer design.
  • Nominal Diameter18"
  • Power Handling (RMS)1,200 Watts
  • Power Handling (max)2,400 Watts
  • Impedance8 ohms
  • Frequency Response35 to 3,000 Hz
  • Sensitivity98 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)31.3 Hz
  • DC Resistance (Re)5.2 ohms
  • Voice Coil Inductance (Le)1.77 mH
  • Mechanical Q (Qms)24.83
  • Electromagnetic Q (Qes)0.40
  • Total Q (Qts)0.39
  • Compliance Equivalent Volume (Vas)12.8 ft.³
  • Mechanical Compliance of Suspension (Cms)0.156 mm/N
  • BL Product (BL)20.65 Tm
  • Diaphragm Mass Inc. Airload (Mms)165.21g
  • Maximum Linear Excursion (Xmax)7 mm
  • Surface Area of Cone (Sd)1,288 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.7"
  • Baffle Cutout Diameter16.2"
  • Depth7.4"
  • Sealed Volume3.97 ft.³
  • Sealed F364 Hz
  • Vented Volume9.71 ft.³
  • Vented F335 Hz
  • BrandPRV Audio
  • Model18SFH2400
  • Part Number294-2753
  • UPC799928733557
    (2 Reviews)
  • Weight33.4 lbs.
View similar products to the PRV Audio 18FH2400 18" Folded Horn Pro Audio Subwoofer 8 Ohm
