PRV Audio 15W700 15" High Power PA Woofer 8 Ohm
Brand:|Model: 15W700|Part # 294-2740
Choose the PRV Audio 15W700 15" woofer for replacing old, worn-out, or blown drivers in your PA speaker cabinet. The 15W700 works equally well in ported or sealed cabinets and offers features not normally found in woofers at this price point.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$86.28
You Save20%
Part # 294-2740
  • 3" voice coil on a Kapton® former for 350W of power handling
  • 5.5 mm of Xmax and a low Fs for playing below 40 Hz with authority
  • Ribbed paper cone captures that "classic tone" of high-end speakers
  • Great 95 dB sensitivity
The PRV Audio 15W700 15" professional audio woofer is designed to be a perfect drop-in replacement for many popular PA speaker cabinets and works equally well in ported or sealed cabinets. A ribbed paper cone is employed to give you the classic tone associated with many high-end speakers.
Moving to the motor, you'll find features not normally associated with other drivers at this price point: a 3" diameter voice coil with a Kapton® former and 5.5 mm of Xmax, high sensitivity, and a fairly low free-air resonance that allows this driver to play down below 40 Hertz. A specially designed resin was been applied to the woven spider for increased longevity, and the cloth accordion surround ensures smooth, accurate sound.
  • Nominal Diameter15"
  • Power Handling (RMS)350 Watts
  • Power Handling (max)700 Watts
  • Impedance8 ohms
  • Frequency Response35 to 3,500 Hz
  • Sensitivity95 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)31.69 Hz
  • DC Resistance (Re)6.4 ohms
  • Voice Coil Inductance (Le)1.33 mH
  • Mechanical Q (Qms)16.27
  • Electromagnetic Q (Qes)0.65
  • Total Q (Qts)0.62
  • Compliance Equivalent Volume (Vas)10.88 ft.³
  • Mechanical Compliance of Suspension (Cms)0.252 mm/N
  • BL Product (BL)13.97 Tm
  • Diaphragm Mass Inc. Airload (Mms)99.87g
  • Maximum Linear Excursion (Xmax)5.5 mm
  • Surface Area of Cone (Sd)935 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter15"
  • Baffle Cutout Diameter14.13"
  • Depth5.51"
  • # Mounting Holes8
  • Sealed Volume13.71 ft.³
  • Sealed F343 Hz
  • Vented Volume27.62 ft.³
  • Vented F321 Hz
  • BrandPRV Audio
  • Model15W700
  • Part Number294-2740
  • UPC799928733618
    (5 Reviews)
  • Weight12.65 lbs.
View similar products to the PRV Audio 15W700 15" High Power PA Woofer 8 Ohm
