PRV Audio 15W1000 15" High Power Waterproof Pro Audio Woofer 8 Ohm
Brand:|Model: 15W1000|Part # 294-2741
PRV Audio's purpose-built, waterproof 15W1000 15" woofer is designed to stand the test of time, when used in pro audio cabinets in nearly any environment.
Comparable Items In Stock:
Part # 294-2741
  • Waterproof cone for use where speakers are exposed to moisture
  • Special resin used in the suspension assembly for durability
  • 3" voice coil and cotton M-Roll surround
  • Relatively flat frequency response allows for use in large format 2-way speakers
Choose the waterproof 15W1000 15" woofer, from PRV Audio, when durability is a priority for your live sound professional audio speakers. Sound quality and accuracy are maintained during intense playback through the use of a suspension that is assembled with a special resin, a stiff and responsive cone, 3" voice coil, a cotton M-Roll surround, and a reinforced steel frame.
The 15W1000 can stand up to heavy use in the worst environments, without sacrificing sensitivity and power handling, and the surprisingly flat frequency response allows this driver to be used in large format, high-efficiency 2-way speaker designs. DJs, dance clubs, and outdoor bars will appreciate the defense provided by the waterproof cone, especially against splashes and spilled drinks.
  • Nominal Diameter15"
  • Power Handling (RMS)500 Watts
  • Power Handling (max)1000 Watts
  • Impedance8 ohms
  • Frequency Response37.68 Hz
  • Sensitivity96.5 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)37.68 Hz
  • DC Resistance (Re)6.4 ohms
  • Mechanical Q (Qms)5
  • Electromagnetic Q (Qes)0.78
  • Total Q (Qts)0.67
  • Compliance Equivalent Volume (Vas)5.94 ft.³
  • BL Product (BL)14.59 Tm
  • Diaphragm Mass Inc. Airload (Mms)109.2g
  • Maximum Linear Excursion (Xmax)4.5 mm
  • Surface Area of Cone (Sd)860 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.11"
  • Baffle Cutout Diameter13.81"
  • Depth5.66"
  • # Mounting Holes8
  • Sealed Volume10.58 ft.³
  • Sealed F346 Hz
  • Vented Volume17.09 ft.³
  • Vented F324 Hz
  • BrandPRV Audio
  • Model15W1000
  • Part Number294-2741
  • UPC799928733601
    (1 Reviews)
  • Weight13.7 lbs.
View similar products to the PRV Audio 15W1000 15" High Power Waterproof Pro Audio Woofer 8 Ohm
