PRV Audio 12W700 12" High Power PA Woofer 8 Ohm
Brand:|Model: 12W700|Part # 294-2730
The do-it-all PRV Audio 12W700 12" woofer is the right choice for use as a woofer, midrange, midbass, or guitar speaker.
  • Versatile design can be used as a woofer, midbass, or midrange
  • Works well as a guitar or bass guitar speaker
  • 3" diameter voice coil for high power handling
  • Great open baffle woofer
PRV Audio's 12W700 12" professional audio woofer features a class leading 3" voice coil and a high sensitivity rating of 98 dB. Use it as a woofer in two-way speakers, a midrange or midbass in large format three-way speakers... the extended frequency response even allows this driver to be used as a guitar or bass guitar speaker, in open back or sealed cabinets!
What sets this speaker apart from other budget 12" woofers is the use of a 3" diameter voice coil and the generous 5.5 mm of Xmax. A stamped steel frame is used to handle abuse while keeping the speaker light. A paper cone combined with a woven cloth surround enables decent sensitivity and creates a natural sound.
  • Nominal Diameter12"
  • Power Handling (RMS)350 Watts
  • Power Handling (max)700 Watts
  • Impedance8 ohms
  • Frequency Response43 to 2,800 Hz
  • Sensitivity97 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)48.54 Hz
  • DC Resistance (Re)6.56 ohms
  • Voice Coil Inductance (Le)1.20 mH
  • Mechanical Q (Qms)15.32
  • Electromagnetic Q (Qes)0.70
  • Total Q (Qts)0.67
  • Compliance Equivalent Volume (Vas)2.49 ft.³
  • BL Product (BL)13.11 Tm
  • Diaphragm Mass Inc. Airload (Mms)60.53g
  • Maximum Linear Excursion (Xmax)5.5 mm
  • Surface Area of Cone (Sd)530.90 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.125"
  • Baffle Cutout Diameter11.02"
  • Depth5"
  • # Mounting Holes8
  • Sealed Volume3.71 ft.³
  • Sealed F355 Hz
  • Vented Volume7.25 ft.³
  • Vented F328 Hz
  • BrandPRV Audio
  • Model12W700
  • Part Number294-2730
  • UPC799928733649
    (3 Reviews)
  • Weight10.15 lbs.
View similar products to the PRV Audio 12W700 12" High Power PA Woofer 8 Ohm
