PRV Audio 12MB800 12" High Power PA Midbass Woofer 8 Ohm
Brand:|Model: 12MB800|Part # 294-2731
Extreme power handling and punchy midbass are the hallmarks of PRV Audio's 12MB800. A great choice for professional 3-way cabinets, floor and studio monitors, even for use in high SPL mobile audio systems.
  • Midbass or midrange for pro audio and high SPL car audio systems
  • Cotton M-Roll surround and dual spider suspension for accuracy
  • 3" voice coil with aluminum former for 400W RMS power handling
  • Strong, lightweight cast aluminum frame
  • Designed for small ported cabinets
  • High 98 dB sensitivity
PRV Audio's 12MB800 12" midbass woofer offers high output punch, a smooth midrange, and response up to 4,000 Hz. The 12MB800 is designed for use as a midbass or midrange driver in 3-way speakers. Alternatively, you can use this speaker in small ported cabinets as a woofer in floor and studio monitors.
A thick, light, and rigid paper cone is mated to a 3" aluminum voice coil former for superior heat dissipation and high power handling. A durable dual spider suspension, M-Roll woven cotton surround, and cast aluminum frame are combined for extreme durability. High output SPL car audio enthusiasts choose this driver for use in their systems when looking for a midrange or midbass that can sustain long hours of extreme operation and keep up with compression drivers and 1,000 watt, and up, subwoofers.
  • Nominal Diameter12"
  • Power Handling (RMS)400 Watts
  • Power Handling (max)800 Watts
  • Impedance8 ohms
  • Frequency Response48 to 5,400 Hz
  • Sensitivity98 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)45.9 Hz
  • DC Resistance (Re)5.5 ohms
  • Voice Coil Inductance (Le)1.37 mH
  • Mechanical Q (Qms)9.15
  • Electromagnetic Q (Qes)0.30
  • Total Q (Qts)0.29
  • Compliance Equivalent Volume (Vas)3.07 ft.³
  • BL Product (BL)17.34 Tm
  • Diaphragm Mass Inc. Airload (Mms)56.67g
  • Maximum Linear Excursion (Xmax)5.5 mm
  • Surface Area of Cone (Sd)530.9 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.6"
  • Baffle Cutout Diameter11.1"
  • Depth5.33"
  • # Mounting Holes8
  • Sealed Volume0.33 ft.³
  • Sealed F3129 Hz
  • Vented Volume0.65 ft.³
  • Vented F381 Hz
  • BrandPRV Audio
  • Model12MB800
  • Part Number294-2731
  • UPC799928733632
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (1 Reviews)
  • Weight21 lbs.
View similar products to the PRV Audio 12MB800 12" High Power PA Midbass Woofer 8 Ohm
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
