PRV Audio 12MB1000 12" High Power PA Midbass Woofer 8 Ohm
Brand:|Model: 12MB1000|Part # 294-2732
PRV Audio's 12MB1000 features a high sensitivity design combined with a cast aluminum frame. Use the 12MB1000 as a midbass and midrange in pro audio 3-way cabinets or as a woofer in small ported monitors. The most powerful 12" midbass in the PRV Audio line is great for high SPL car audio systems.
  • Midbass or midrange for pro audio and high SPL car audio systems
  • Cotton M-Roll surround and dual spider suspension for accuracy
  • 4" voice coil with aluminum former for 500W RMS power handling
  • Strong, lightweight cast aluminum frame
  • Designed for small ported cabinets
  • High 97 dB sensitivity
The 12MB1000 12" PRV Audio midbass woofer is the most powerful 12" midbass loudspeaker in the PRV Audio line. A cast aluminum frame is used for extreme durability. Designed to be used as a midbass or midrange driver in large format 3-way speakers, the 12MB1000 can alternatively be used in small ported cabinets as a woofer in floor and studio monitors.
Dynamic, punchy midbass is generated from the sensitive, 500W RMS power handling motor design that features a large, 4" diameter voice coil with aluminum former. Two durable woven spiders (coated with a special resin) are combined with a treated cotton M-Roll surround for accurate travel, and a thick, rigid paper cone for years of trouble-free operation, even in the most demanding high SPL car audio systems.
  • Nominal Diameter12"
  • Power Handling (RMS)500 Watts
  • Power Handling (max)1,000 Watts
  • Impedance8 ohms
  • Frequency Response60 to 3,500 Hz
  • Sensitivity98 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)60.56 Hz
  • DC Resistance (Re)5.8 ohms
  • Mechanical Q (Qms)2.93
  • Electromagnetic Q (Qes)0.39
  • Total Q (Qts)0.35
  • Compliance Equivalent Volume (Vas)1.33 ft.³
  • BL Product (BL)20.28 Tm
  • Diaphragm Mass Inc. Airload (Mms)73.1g
  • Maximum Linear Excursion (Xmax)5 mm
  • Surface Area of Cone (Sd)542.4 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.4"
  • Baffle Cutout Diameter11"
  • Depth4.42"
  • # Mounting Holes8
  • Sealed Volume0.29 ft.³
  • Sealed F3140 Hz
  • Vented Volume0.64 ft.³
  • Vented F383 Hz
  • BrandPRV Audio
  • Model12MB1000
  • Part Number294-2732
  • UPC799928733625
    (1 Reviews)
  • Weight24.5 lbs.
View similar products to the PRV Audio 12MB1000 12" High Power PA Midbass Woofer 8 Ohm
